car wont start timing help please - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2009, 06:00 PM
i have a chevy 355 vortec heads flat top pistons and holley 650 cfm carb i got every thing hooked up and when i try to start it the exust pops and the carb backfires but dosnt start and advise or idea would be great thank you if you need more info just ask
Old 10-20-2009, 06:24 PM
SSedan64's Avatar
Timing Retarded or Distributor installed incorrectly>>>
http://www.chevytech.com/3c1.html
http://www.chevytech.com/2c44.html
Old 10-20-2009, 06:31 PM
RSM's Avatar
RSM RSM is offline
Sounds like your 180 degrees off on the dist. or you have some seriously tight valve adjustments. Check your timing and make sure the dist is in correctly.
what is the fastest (factory) car you have ever driven? badknuckles Hotrodders' Lounge 320 12-09-2011 01:32 AM
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
car won't start please help SBC S-10 Engine 4 08-11-2005 08:42 PM
car well not start impala dreaming General Rodding Tech 6 02-22-2003 05:09 PM
