Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Car wont turn off with ignition
Old 07-02-2012, 07:51 PM
vicrod's Avatar
vicrod vicrod is offline
life is a ride
Last journal entry: 2014
You need to make sure you have 1 wire feeding the HEI from the ignition switch or switched circuit. No resistor wire or wire from the starter.
I am assuming this problem started when you changed from points to HEI.
Check it with test light.
vicrod
