Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Car wont turn off with ignition
Old 07-03-2012, 01:51 PM
vicrod's Avatar
vicrod vicrod is offline
life is a ride
Last journal entry: 2014
Elkay65
When you turn off the ignition does the wire to the HEI go to 0 volts?
If not something is wrong with the wiring to the fuse block or the ignition switch is bad.
The one wire alternator should be connected the battery side (hot at all times) of the fuse block. If connected correctly a one wire alternator cannot feedback to the ignition. Double check the alternator connection. As a test disconnect it and see if the problem goes away.
vicrod
