Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Car wont turn off with ignition
Old 07-04-2012, 12:33 AM
ronbuhg's Avatar
ronbuhg ronbuhg is offline
Originally Posted by vicrod View Post
When you turn off the ignition does the wire to the HEI go to 0 volts?
If not something is wrong with the wiring to the fuse block or the ignition switch is bad.
The one wire alternator should be connected the battery side (hot at all times) of the fuse block. If connected correctly a one wire alternator cannot feedback to the ignition. Double check the alternator connection. As a test disconnect it and see if the problem goes away.
just for my understanding, should the battery feed at the fuse block be fused ?? Im thinking no, but Im not that smart on electronics I admit....
