Car wont turn off with ignition - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-04-2012, 07:36 AM
P
The stock setup uses the starter as a junction point. The output from the alternator runs to the starter and it has a fusiBle link where it connects to the starter post. Then there is a wire from that junction to the battery positive and a wire to the fuse box. Each wire has a fusible link, but no fuse. However, that junction is under the vehicle where it not convenient to reach.
Newer vehicles run the charge wire directly over from alternator BAT to the battery positive, and put the fusible link on the battery end. I pulled that setup off a junked GM vehicle because it gave me a larger charge wire (8 gauge?) for my new alternator.
Bruce
  #17 (permalink)
Old 07-04-2012, 05:17 PM
EOD Guy's Avatar
I installed a 70 amp Maxi fuse on the output from the Pos battery post, everything runs thru it except the cable that goes to the starter. That was the setup that came with the Painless kit I bought..... works well.
  #18 (permalink)
Old 07-04-2012, 06:13 PM
vicrod and dub I found my problem,the bus bar connection from the main source was loose on
the back side of the fuse block.Body panel glue is great.
thanks you guys for all your help. Ealkay65
  #19 (permalink)
Old 07-04-2012, 08:04 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
Do you mean that the main power was contacting the ignition bus on the fuse block thus keeping the ignition hot at all times?
vicrod
  #20 (permalink)
Old 07-05-2012, 06:14 PM
Vicrod ,yes, you are correct ,the main power was contacting the ignition hot all the time.
good thing i disconnect the battery wheni am not working on the car.I went through the fuse box and all related wires.Thanks again for your help Elkay65
Car wont Turn over Death1990 Hotrodding Basics 3 03-06-2012 05:16 PM
car wont turn over when it is warm chris 37 Hotrodding Basics 8 12-28-2011 02:28 PM
car wont turn off by the ignition lock switch 84buick Electrical 9 12-11-2011 07:29 PM
low beams wont turn on , but if i turn high beams on logic-ali Electrical 11 06-23-2011 03:51 PM
It wont turn over mrbankston86 Introduce Yourself 1 07-22-2010 06:44 PM
