Car wont turn off with ignition - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2012, 11:43 PM
dub's Avatar
dub dub is offline
Last journal entry: Time to drive..
Ok......And yet again, I am on this great site asking for more help.
The car will start with the ignition as normal, but when I go to turn it off, the engine remains running. I have a HEI ignition, and I assume that the once power is killed to the cap/coil, the engine should turn off. Well, I have a wire going directly to the fuse panel under the dash, I tested the terminal that I plugged it into, it has switch power. But the engine doesnt turn of when I turn the ignition off. Which tells me that I have constant power at all times. Did I wire the engine bay wrong? I also tested the wire that goes to the alternator, and it has 12V at all times. Is that right? Does anyone have any ideas?
Thanks again,
Mike
Old 06-16-2012, 12:32 AM
ronbuhg's Avatar
Thanks again,
Mike
When you turn it off , does the engine run on for a short time or stays running for awhile till you kill it ,however your doing that ?? If the electrical power is OFF when key is turned off, then I suggest you look at your idle speed. If its too high it will continue to run due to compression & fuel ,even with no electrics to spark it.. basically like the big tractor~trailers..hope thats it, but you need to fix it asap, because desiel run~on isnt good for the motor..let us know,,hey guys am I right or wrong here ??
Old 06-16-2012, 12:35 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
run on
msd has an issue with that. the alternator will continue to power the switched side of the wiring. install a diode on the field wire. this article discusses older versions but i've had problems with hei doing the same thing.
http://www.msdignition.com/page.aspx?id=3296
Old 06-16-2012, 12:37 AM
dub's Avatar
dub dub is offline
Its definatley not deisiling. I have to physically pull of the bat cable to kill the engine. Its for sure an electrical problem.
Old 06-16-2012, 12:43 AM
dub's Avatar
dub dub is offline
msd has an issue with that. the alternator will continue to power the switched side of the wiring. install a diode on the field wire. this article discusses older versions but i've had problems with hei doing the same thing. http://www.msdignition.com/page.aspx?id=3296
Then it makes me think what the previous owner did before....How did he turn the car off? Is this a type of problem that just starts to happen overtime? Ill get a diode tomorrow and see what happens.
Thanks,
Mike
Old 06-16-2012, 12:53 AM
bracketeer's Avatar
489 Lemans
more info
GM: Delcotron Alternators use an internal voltage regulator. Install
the Diode in-line on the smallest wire exiting the alternator (Figure
7). It is usually a Brown wire.
stripe on diode towards alternator.
Old 06-16-2012, 02:14 AM
ronbuhg's Avatar
sorry I was wrong, I misread the question,maybe I better not give out anymore 'advice'
Old 06-16-2012, 04:34 AM
EOD Guy's Avatar
Place the diode on the #1 terminal....... I suggest removing the #1 wire from the connector, go to NAPA and buy a female and male type 56 terminal (OEM type) crimp the diode to the new terminals, insert it into the alt connector, place the old wire onto the new diode, cover the whole thing in shrink wrap. That way if it ever goes south and needs replacing..... it's a simple
Plug-N-Play deal
Old 07-02-2012, 07:30 PM
Hi All,I have a 1965 chevelle with hei and one wire alt that also wont shut off with the key.I have to pull the battery cable off to stop it.I plugged my HEI power wire into the fuse panel after i removed the old wire for the points system
HELP,lumpy65
Old 07-02-2012, 07:51 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
You need to make sure you have 1 wire feeding the HEI from the ignition switch or switched circuit. No resistor wire or wire from the starter.
I am assuming this problem started when you changed from points to HEI.
Check it with test light.
vicrod
Old 07-02-2012, 08:54 PM
elkay65
Vicrod
I DONT HAVE ANY RESISTOR WIRE ANYMORE.i PICKED UP POWER AT THE FUSE PANEL AT ''FUSED IGNITION'' AND RAN THE WIRE RIGHT TO THE hEI.
I CHANGED THE ALTERNATOR AT THE SAME TIME.COULD THE ALT BE BACK FEEDING?
ELKAY65
Old 07-02-2012, 11:05 PM
dub's Avatar
dub dub is offline
I had the same issue obviously. The power to the HEI was in the wrong fuse terminal the entire time. In the center of the fuse block, there are a row of terminals that you can use. I used the one all the way at the bottom, its marked "IGN" That's one of the few terminals that kills power when the ignition is in the "off" position. Run that wire directly to the HEI power terminal.
Hope this helps.
Mike
Old 07-03-2012, 01:51 PM
vicrod's Avatar
life is a ride
Elkay65
When you turn off the ignition does the wire to the HEI go to 0 volts?
If not something is wrong with the wiring to the fuse block or the ignition switch is bad.
The one wire alternator should be connected the battery side (hot at all times) of the fuse block. If connected correctly a one wire alternator cannot feedback to the ignition. Double check the alternator connection. As a test disconnect it and see if the problem goes away.
vicrod
Old 07-03-2012, 05:02 PM
thanks Vicrod and Dub , i check out your ideas and get back to you
Elkay65
Old 07-03-2012, 11:33 PM
ronbuhg's Avatar
Originally Posted by vicrod View Post
Elkay65
vicrod
just for my understanding, should the battery feed at the fuse block be fused ?? Im thinking no, but Im not that smart on electronics I admit....
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Car wont Turn over Death1990 Hotrodding Basics 3 03-06-2012 05:16 PM
car wont turn over when it is warm chris 37 Hotrodding Basics 8 12-28-2011 02:28 PM
car wont turn off by the ignition lock switch 84buick Electrical 9 12-11-2011 07:29 PM
low beams wont turn on , but if i turn high beams on logic-ali Electrical 11 06-23-2011 03:51 PM
It wont turn over mrbankston86 Introduce Yourself 1 07-22-2010 06:44 PM
