is this car worth it? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2009, 06:24 PM
Wiki Edits: 31
I found a 1973 Olds Cutlass 2dr coupe on Ebay, $900 starting bid, no reserve and nobody had bid on it.. I live out in the country, and supprisingly the car was only a short distance from me, so I went and looked at it... it is a 30 footer, looks decent even up close, but you can tell the flaws up close.. It has a 350 Rocket V8, and automatic trans, rolled over odometer so probably 117,000 as it reads 17,141.. it has been painted amaturly ( paint might be inferior, does not shine well, but there is no overspray or anything, but deffinatly not brushed or rolled ) and I can tell there is a lot of bondo on the passanger side by knocking on the 1/4's and rockers, but it does look like it was done good at least.. but the driver side is solid... it runs good, has new tires, new brakes, new dual exhaust, dash is good, gauges look good and work, trans shifts and it could pass NY inspection as is, but it does need work.. driver side floor is soft, and I could patch it, but all others are good.. rear window has had trim and gasket removed so it has leaked over the winter.. seats are good, and it does not show too much water damage ( the vinyl by the 1/4 windows is coming apart from the foam )... The sketchy part is, right after I got home ( 20 min drive ) the listing was removed.. the guy was talking about taking the tires and putting them on his car.. my thinking is he thinks I'm the only 1 interested, so he can sell it locally at his price w/o the $125 hit from Ebay and Paypal fees.. he told me in a couple days he could show it to me on his lift, after he gets his truck off it..... I really don't want a project, but a simple older car that will get attention and I can drive daily for the spring and sell it b4 summer is over.. concerns with Gas mialage is I don't have a clue what to expect from it, as it has an older aftermarket intake ( brand unknown, but it's aluminum and has no GM casting number or firing order ) with a 4150 Holley 4bbl, and my budgeting allows for 18 MPG minimum, but I really don't need anything more than 22-23 or so... I'm done with the matchbox econobox cars, and until I absolutly need above 30 MPG, I doubt I'll own 1.. If I can't find a decent older car to drive, then I'll fix my Ranger or get another 1.... is the '73 Cutlass worth getting?
I could probably offer $1,200 and drive it home.. I think the reason he got no bids is due to the economy and the fact the town it is in.. a lot of people do not know exist's, and he lives wayy out beyond where I'v ever gone, and yes, I did get lost and have a hard time finding his place.
Old 03-17-2009, 06:57 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
Did you get any pics of it Matt?
Old 03-17-2009, 07:13 PM
you get what you pay for. sounds like you have the right ideas as to how to determine the weak points. It is definately going to be a project. I dought you will see a return on your investment? Good Luck
Old 03-17-2009, 07:26 PM
Wiki Edits: 31
I didn't, just have a laser printout of the ad that I could scan a couple of the pics off of, but because it's laser and B&W, there not good
Old 03-17-2009, 07:54 PM
Wiki Edits: 31
the original Olds Ralley rims with the fake spokes and trim rings, have been blasted and painted glossy black, and look very nice, and the trim rings are nice- may be the nicest parts on the car
if I do some rough guessing on cost to fix stuff
$200 to fix the rear window
$10 for some headliner adhesive and patcience to fix the separated vinyl
$100 for a driver side floorboard ( I assume a reproduction Malibu peice will work? )
$100 for missing valance panals above rear 1/4 windows ( assume maby dome lights go there, but I see no wiring )...
so if I got it for $1,200, and put$410 into it, I'd have $1,610 in a 30 footer.. but then the question would be, would there be a return investment? I don't know the going price on mid 70's GM midsize, other than they are getting more popular.
NADA says $3,420 low retail, or $7,710 average, but is that what they really go for?? if this is the case, I could put a $2,500 price tag on it and most likely sell it quick
Old 03-17-2009, 08:01 PM
Irelands child's Avatar
Matt - if you are looking for an 18 mpg car, this isn't what you need. Oldsmobiles were OK for their time frame, 13-15 in good tune, but a '73 was right at the first gas crunch time - and had rudimentary emissions controls that for sure didn't give you gas mileage. Then a Holley 4150 or even a 4160 is not an economy carb. Then add in a points ignition, a 4000+/- pound car, a TH350 tranny (maybe) then a 2.7 rear gear and you have a hog for general driving on the hilly roads of the Catskills.
And do you want it as a beater or a resto project - either of which puts it in different categories
Dave W
Irelands child
Old 03-17-2009, 08:15 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Matt i dont know what they would go for where you are at.but i do know one sold here just the othe day for $4000 orange and black 455 engine.rough but very restorable.just trying to help.but as far as a good return thats just hard to say. cole
Old 03-17-2009, 08:34 PM
Wiki Edits: 31
Dave W
That and the fact, it sounds so cool when the back 2 barrels of a 4bbl open up at WOT probably couldn't keep my foot out of it ... I don't need another project, The Falcon's arleady on Ebay due to having 1 project too many... I didn't look to see what all emissions stuff was still there, but I do know the smog pump was.. don't think it had an EGR, but I really didn't look.. there's a kid I know, looking for a cool old car to fix up with his dad.. I'll probably tell him about it, because it is a good deal.. just not practical for me right now
Old 03-19-2009, 05:35 PM
Wiki Edits: 31
I think I found what I want, just don't know how to calculate the fuel for diesel being the prices fluctuate so much... I found this truck, a 1986 Ford F-250 with the old 6.9L non turbo Diesel and 86,000 miles.. haven't looked at it yet, but I intend to, and it looks good in the pics.. comes with a truck camper, but there is little in the description.. what kind of fuel economy would the 6.9L bring? would it start without a block heater in the winter, with just good glow plugs?...
Old 03-19-2009, 05:52 PM
Wiki Edits: 31
http://cgi.ebay.com/ebaymotors/ws/eB...0380&viewitem=
Old 03-19-2009, 06:53 PM
Matt - in your part of the world - at least a dipstick heater would be necessary. The 6.9 and 7.3 Ford/Navistar diesels are good for 300,000 miles tho that '86 body wont last here in the rust belt. Fuel economy - 18 to 22 isn't unheard of with those beasts.
Dave W
Irelands child
Old 03-19-2009, 07:10 PM
Big Don's Avatar
Olds
BUY IT! They ain't making anymore. Folks pay that much for a soilid donor car these days.
Old 03-19-2009, 08:07 PM
Wiki Edits: 31
Dave W
with the rust starting to show in the bottom of the wheel wells, what could be done to prevent it from getting worse? If I got it, I would address the rust immediatly, and get a new 2 tone paint job, Red and black when I sell the Falcon or Ranger... it seems pretty solid from the pics, but can't tell for sure till I see it up close... I would get rid of the old red bug deflector too..
Old 03-20-2009, 02:14 PM
Big Don's Avatar
Rust!!!!
Rust isn't always abad thing. Usually means that it is metal:-) Depends on how badly it is rusted... In the old days we used to qualify the rust as surface, pitting, or just plain old cancer. Cancer or metal rot is the one thing to avoid. Anything else can be dealt with.
Rot or cancer means major cutting and replacing of sections. Media blasting at low pressure can usually solve most problems. Simply clean it up, treat the areas and then paint the puppy. No sweat!
Old 03-20-2009, 04:47 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I once had a '76 Olds Cutlass, buckets and console. Blew up the Buick V6 that it came with (was gonna swap it anyway) and put a 455 out of a Vista Cruiser in it.
That was a FUN car!!! Room enough for 5 (6 if half were female ) but naturally, mileage was terrible. Sold it for $3K, and it had zero rust or dents, but the original paint was tired. It took a while to sell it, this was in FL.
Here in GA you'd be hard pressed to get that much for the car, but it's worth "what it's worth" to the right person. A motivated buyer is all you would need.
But w/the economy the way it is, plus an uncertain energy supply, a 14 mpg car might be a hard sell in the months/years to come.
I wouldn't buy the car expecting anything except maybe breaking even.
Good luck!
donk or lambo's got nothing on this 406chevycaprice Hotrodders' Lounge 28 01-28-2008 08:09 AM
Car theft - by a VIN Irelands child Off-Topic 6 01-14-2008 09:44 AM
Three different paint shops suggested 2 different ways of painting the car, opinions? Ripped Body - Exterior 8 04-30-2007 02:05 PM
What do you think my car is worth? 40chevy Hotrodders' Lounge 10 03-20-2006 06:50 PM
