-   Garage - Tools (http://www.hotrodders.com/forum/garage-tools/)
-   -   Caraholic tip (http://www.hotrodders.com/forum/caraholic-tip-76336.html)
Chris Gerloff 12-16-2005 10:19 PM
Caraholic tip
Keep a bottle of "Oil of Wintergreen" in your garage. You have to get it from your pharmacy but it works better than Nut Buster, WD-40, Liquid wrench or anything I have found. It's an old shipyard trick, they deal with some pretty serious rust on ships on a regular bases.
predator carb guru 12-17-2005 01:35 AM
oil of wintergreen? never heard of it in my life...........but now you have my curiosity up, so i'm gonna have to try it................
tm454 12-17-2005 01:26 PM
Oil of wintergreen...
I have heard of it before but I don't remember the proper application. I use trans fluid to bust the rust on badly corroded nuts or bolts. When I don't have any old trans fluid around I use PB Blaster as a penetrant.
Tazz
Chris Gerloff 12-17-2005 05:00 PM
Oil if wintergreen
I have also used tranny fluid but it is not a viscous as wintergreen and doesn't penetrate as well. I think the penetration quality is the key to its effectiveness but what ever works for you is cool. Just trying to save a little knuckle skin.
