Carb - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2008, 05:59 PM
Carb
ok well im thinking of getting a new carb for my 75 vette. Right now i have a Holley 750 Vac Seconday dual feed 4160. My specs for the vette are th400 tranny, 355 sbc with vortec heads, 218/228 @.050 .520 lift cam, Preformance Products RPM Airgap Inake, Accel HEI Super Coil. 3.08 rear. Im getting tired of having to mess with the holley all of the time. Seems about every other month I have to mess with it to get it to run right or try not to run rich. Im thinking of ditching the holley and getting a q-jet. So whats the best carb for street use. Any advice is appriciated. Thanks in advance.
Old 09-16-2008, 06:08 PM
DoubleVision's Avatar
Unless the intake your using has a speadbore pattern for a Q-jet as most of them don`t then you`d have to use a adapter which will make problems worse. What kind of issues is your holley giving you? if it keeps doing the same thing there has to be a reason why.
Old 09-16-2008, 06:12 PM
It will not keep tune. like i stated at least once a month i have tune the stupid thing. Also it has a little hesitation and runs rich. I have been messing with this thing since it was bolted on the car over 2 years ago. My buddy who is a boat mechanic help with it and thought we had it until last weekend when i drove the car and it was running rich again and the hesitation was getting worse. Im just tired of dealing with this stupid holley. Maybe the 750 is too big for my application?
Old 09-16-2008, 08:06 PM
with the car at idle, shine a light in the carbs throat, do you see any fuel dripping out of the boosters? when you shut it down does white smoke pour out of the carb? Whats the fuel pressure? is there a fuel pressure gauge?
This sounds like a fuel pressure issue, it can leave you chasing a problem you can`t correct for long.
Old 09-16-2008, 08:13 PM
There is no smoke out of the carb. The fuel pressure is about 5 to 7. The guage jumps but the pressure is under 7. i need to get a new guage I noticed it has went bad and not reading the pressure, probably went bad due to water getting in my gas tank and then me sucking though not knowing it was in the tank. I have the holley dvd and a book and Lar's Papers on Holleys and have done everything that was advised, but still can not get the rich smell or hesitation gone.
Old 09-17-2008, 04:26 AM
Then likely you could swap over to a Holley 670cfm street avenger carb. I`ve played with a few of these and they are pretty good carbs and should be just right for your application.
Old 09-18-2008, 03:49 PM
Ok well i adjusted the mixture screws a little and got it a little better. Still smells a little rich. Check the plugs and they are a good Tan Color. Also got my pressure guage fixed. It looks like its about 7psi. The gauge jumps bad when at idle and when i rev the car a its kind of starts to steady out a about 7psi. If a remeber correctly its a carter factory style fuel pump. Has the return and feed line and the feed line to the carb.
Old 09-18-2008, 04:37 PM
Rich you can't get rid off is usually the fault of the power valve. Either dirt caught in it holding it open or the diaphragm is ruptured from a back fire, kit available to soothe this problem, or the valve is not installed properly.
Bogie
Holley 4777 carb. questions. TVR383 Engine 16 07-05-2009 02:23 PM
Demon or Holley Carb for 306 Ford? Dino Boreanaz Engine 10 12-09-2006 06:04 PM
700 R4 tv cable hook up at carb murrsue Transmission - Rearend 4 10-18-2006 09:50 AM
Holley Carb. Question crusherdbuzz Engine 2 07-02-2006 03:25 PM
Holley carb has me at wit's end cool rockin daddy Engine 23 06-02-2005 02:38 PM
