Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Which Carb?
Thread: Which Carb?
Old 09-15-2012, 02:53 PM
Madmax305's Avatar
Madmax305 Madmax305 is offline
OK, I put the new Edelbrock 650 carb on and installed the new 10* advance bushing in the MSD distributor. I tried to adjust the base to 24-26* but the starter bucks and I can't get the motor to take that much base timing. The most I can get is about 16-18* before the starter bucks and will not crank the engine fast enough to start it...
Any other options? What about hooking up to the manifold vacuum vs ported vacuum to help add 10-12* to the base. Would this help me achieve the 24-26* initial timing?
