carb. - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2013, 04:09 PM
carb.
Whats the best carb to put on a 327 bored 30 over mild cam? looks like it has a 600 holly on it now. Lots of play in throttle shaft, I think it is not worth rebuilding. It looks ruff.
Old 03-17-2013, 05:33 PM
33Willys77's Avatar
What are your plans - what are you wanting to do with it? Basic easy install for simple street use and mileage - Edelbrock would do fine. Holley or other type (such as Quick Fuel) will give the most performance. Either way, you need to tune it correctly for the best outcome.
The Following User Says Thank You to 33Willys77 For This Useful Post:
fastfrank (03-17-2013)
holley carb backfires threw carb talleyho Engine 63 01-04-2016 10:43 AM
Best carb spacer style Edelbrock carb truckboy61 Engine 2 07-24-2011 09:18 AM
Will adding a 1 inch carb spacer affect carb tune? eric32 Engine 29 02-09-2010 12:13 AM
Quadrajet Carb rebuild....parts interchange with another junk carb? Warrant Engine 2 07-31-2006 10:44 PM
Any problems spraying carb cleaner in my carb while its on the motor? batman09 Engine 11 11-29-2005 07:49 AM
