carb. for a 283 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2011, 01:49 PM
carb. for a 283
I`ve got a stock 283 in 56 chev. it has an old rochester with no choke except a rod out of manifold. I want to get a carb. that has at least a choke to adjust by turning left or right for tension, and it would be nice to have a vacuum pull off too. I was told that I have the small manifold bolt pattern on this 2 bbl. setup. Can you folks recomend a carb. ? Can I get a different manifold plate adaptor, or? Don`t care to spend much money on this. Thanks
Old 04-30-2011, 02:01 PM
seawolf18's Avatar
Do you want to stay with a two barrel, or go four barrel carb?
Old 04-30-2011, 03:59 PM
I would like to get decent gas mileage, so I guess I should stick with a 2bbl.
Again, I want to keep the cost down. Thanks
Old 04-30-2011, 06:47 PM
a properly tuned qjet can get better fuel mileage then a 2 bbl
Old 04-30-2011, 06:53 PM
techinspector1's Avatar
Wiki Edits: 326
Originally Posted by va4cqd
a properly tubed qjet can get better fuel mileage then a 2 bbl
Correct, the primary venturis and throttle bores of the Quadrajet are smaller than those of the 2-bbl. As long as you keep your foot out of the secondaries, a Quadrajet is about as good as it gets for fuel mileage.
Old 04-30-2011, 06:59 PM
You could scout your local junk yards and try to find a 2gc with the thermo choke.Not hard to rebuild at all.If you find one just check the throttle plate shaft to see if it is worn.
Old 04-30-2011, 07:16 PM
Hey Techinspector1, I am also in AZ. and would like to know where I could get a quadrajet for my 283 that is not too costly. What would I need to bolt up to my manifold? I was told I have a small bolt pattern on my 283. Thanks for any help from you members.
Old 04-30-2011, 07:18 PM
you need a spreadbore 4 barrel intake
PS, I can rebuild the qjet myself if I need to. Thanks
Old 04-30-2011, 07:28 PM
ok, dumb me i forgot i need to change manifold, so i will keep looking for a 2bbl. what years or what carbs would fit my 283 manifold? thanks
Old 04-30-2011, 07:34 PM
you can probably find a stock 4 bbl manifold for like $20
Old 04-30-2011, 07:56 PM
Hippie's Avatar
Last journal entry: HEI comparison.
If you have a "rod" coming out of the manifold it sounds like you have a divorced choke which dates your intake and carb from around 1966 to about 1977 and your carb is a Rochester 2GC. A hand choke version was available on trucks through 1966 and '65 and older passenger car versions had a hot air choke that fed off a tube from the exhaust manifold. At one time you could get kits to convert those to electric choke. If you did some searching you might find a reman. carb and one of the choke conversion kits. During the 70's and 80's Holley had an Economaster carb that was a direct replacement for the 2GC. NOS Economasters pop up on eBay occasionally. The 2G ( no choke ) and 2GC are getting easier to find parts for with the popularity of traditional rods as they were used on many multi-carb setups and some new goodies are being produced again.
Personally I'd ditch the 2 bbl. for Q-Jet or 450 spreadbore Holley on an iron Q-Jet intake or a '66 cast iron intake for a Holley or Carter AVS with a Holley R-8007 390cfm electric choke 4160 series 4 bbl. It will run better and get better mileage and the secondaries can be adjusted to delay the opening. The Q-Jet's secondaries can be locked out all together with the air valve adjustment.
Old 05-01-2011, 08:45 AM
Thanks Hippie and others for the good info. I wish I could find a $20 intake and $75 Qjet or holly, but I live in a realative small town north of PHX. with one wrecking yard and no cars in the 60 0r 70s range. And not knowing what to ask for on ebay has gotten me burnt a couple times. I guess I`ll look for an econimizer on ebay. Thanks
Old 05-01-2011, 06:03 PM
willowbilly3's Avatar
Last journal entry: Body mods
That was always a great theory but never worked for me, oh wait, that was because my size 13 just gets heavy.
I used to like to find the old 2G from a pickup so I had a good manual choke and didn't have to mess with the problematic and poorly engineered automatic chokes of that era. I still pick them up every time I see one, probably have a half a bushel of them around here somewhere.
Old 05-01-2011, 06:30 PM
Wiki Edits: 326
I haven't used an automatic choke since the first one I ever had. Hated it and changed to a manual. Never looked back. If you install a microswitch on the carb that is actuated by the choke rod, then you can install a small colored bulb of your choice (Radio Shack) on the dash to remind you that the choke is on. You can even incorporate a flasher in the line if you're really unconscious like me.
holley carb backfires threw carb talleyho Engine 63 01-04-2016 10:43 AM
Will adding a 1 inch carb spacer affect carb tune? eric32 Engine 29 02-09-2010 12:13 AM
Quadrajet Carb rebuild....parts interchange with another junk carb? Warrant Engine 2 07-31-2006 10:44 PM
Any problems spraying carb cleaner in my carb while its on the motor? batman09 Engine 11 11-29-2005 07:49 AM
Which Carb Stevestang1966 Engine 3 03-23-2003 03:51 AM
