-   -   carb. for 283 (http://www.hotrodders.com/forum/carb-283-a-220535.html)
constructionsarge 06-14-2012 02:23 PM
carb. for 283
what is the best combo intake and carb for stock 283?
DoubleVision 06-14-2012 03:48 PM
Weiand action plus, Edelbrock Performer for intake.
Rochester Quadrajet for a carb.
Or you could just get a factory cast iron Quadrajet intake which will work just as well on a stock engine if you wanted to go the cheapest route.
There are also factory aluminum Quadrajet intakes out there as well.
lg1969 06-14-2012 09:15 PM
Hi, You can try a Holley 390VS #8007 and use a square bore type alum high rise dual plain manifold. It should run very nice. hope this helps.
1930u 06-15-2012 09:15 PM
The old Holley 6210 with stock Q-jet manifold is a great combo especially with a 4-speed and 3:55 through 4:11 gear.
vinniekq2 06-21-2012 01:04 AM
carb/manifold
I used a 625 carter on a street master intake and was very happy with it.For performance a holley 600 double pumper long bowl works for power but fuel economy suffers a lot.
327NUT 06-21-2012 02:33 AM
A double pumper on a "stock" 283??? I don't think that is a wise recommendation.
ap72 06-21-2012 07:38 AM
Edelbrock 1406 carb on a edelbrock performer intake. Its cheap, very effective, and idiotproof. A holley or quadrajet will work too, but they're more complex.
krypty 06-21-2012 10:30 PM
Id go with a stealth intake and the q-jet... those carbs are without a doubt great for stock applications....Modified they are even great on street/strip performance too...
