carb. for 283 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-14-2012, 02:23 PM
carb. for 283
what is the best combo intake and carb for stock 283?
Old 06-14-2012, 03:48 PM
DoubleVision's Avatar
Weiand action plus, Edelbrock Performer for intake.
Rochester Quadrajet for a carb.
Or you could just get a factory cast iron Quadrajet intake which will work just as well on a stock engine if you wanted to go the cheapest route.
There are also factory aluminum Quadrajet intakes out there as well.
Old 06-14-2012, 09:15 PM
lg1969's Avatar
Google "Tunnel Ram 406"
Hi, You can try a Holley 390VS #8007 and use a square bore type alum high rise dual plain manifold. It should run very nice. hope this helps.
Old 06-15-2012, 09:15 PM
1930u's Avatar
Last journal entry: 1930u Its just been sitting
The old Holley 6210 with stock Q-jet manifold is a great combo especially with a 4-speed and 3:55 through 4:11 gear.
Old 06-21-2012, 01:04 AM
vinniekq2's Avatar
carb/manifold
I used a 625 carter on a street master intake and was very happy with it.For performance a holley 600 double pumper long bowl works for power but fuel economy suffers a lot.
Old 06-21-2012, 02:33 AM
327NUT's Avatar
A double pumper on a "stock" 283??? I don't think that is a wise recommendation.
Old 06-21-2012, 07:38 AM
Banned
Edelbrock 1406 carb on a edelbrock performer intake. Its cheap, very effective, and idiotproof. A holley or quadrajet will work too, but they're more complex.
Old 06-21-2012, 10:30 PM
Id go with a stealth intake and the q-jet... those carbs are without a doubt great for stock applications....Modified they are even great on street/strip performance too...
Which carb and Manifold for 283 john 1463 Engine 3 04-29-2012 09:10 PM
what carb should i use on a 283? d63ss Engine 8 10-16-2011 05:23 PM
Carb suggestions for a 283 luckynumberslevin Engine 24 07-17-2011 08:18 PM
carb. for a 283 db flyer Engine 14 05-01-2011 07:30 PM
best carb for 283 81elcamino Engine 9 07-29-2003 04:20 PM
