Carb for a 347 Stroker?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-22-2008, 06:36 PM
Old Pony's Avatar
Im building a 347 stroker thatll produce about 400 HP. Ive got all sorts of opinions on carbs for it from the 650 Holley 4150 HP, to a Thunder Series AVS Edelbrock 800. I need to call upon the voices of experience. If it was my motor Id use a .
Thanks guys!!
Old 09-22-2008, 09:24 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
If it were my motor I would use a Qjet. No, seriously, I would. Second choice would be a Holley vac sec 600.
Here's the breakdown. A 347 at 90% VE and 6000 rpms will ingest 542 CFMs. Anything more than 600 and you're giving up torque, throttle response, tunability, and drivability for no measurable increase in HP.
Old 09-22-2008, 10:12 PM
Rustydawg's Avatar
Cruzin w/Elvis in Bigfoots UFO
If it were my motor (and someone else was footing the bill) I'd put EFI on it.
If it's sitting in a light chassis with a manual transmission and 3.90s I'd put a 650 mech secondary on there.
But don't listen to me, I could be a crackhead that can still type OK. Call some of the carb makers' tech lines, be honest about what you've got and see what they have to say.
There are significant benefits to a mechanical secondary carb - it can make for a reduced pressure drop across the carburetor and greater cylinder filling so long as your engine and gearing work with it. That's the key.
Send a PM to the Barry Grant tech fellow on this board and he can suggest something - just include all the details about your ride.
Old 09-22-2008, 10:32 PM
j.d.brown.042964's Avatar
406 Caprice:Rust Never Sleeps!
A Q-jet would be a nice touch to a Ford motor-wouldn't it? If nothing else it would probably give you the best chance at anything resembling mpg's, due to the fact that they'll only deliver what the engine can utilize. Definitely a point to consider with todays fuel prices!-Jim
Old 09-22-2008, 11:16 PM
Thanks guys!!
I've built quite a few 347's. The tamest one was 430HP w/440 ft.lbs. of torque! Cast iron Street Heat heads with just port matching. 292H Comp Cams hydraulic cam, Victor Jr. intake and a 750 Holley Double Pumper. Very relaible street combination also....
Old 09-23-2008, 01:49 AM
curtis73's Avatar
Wiki Edits: 16
Ford used a spreadbore for a while with the 4MV carb.
Old 09-23-2008, 01:53 AM
curtis73's Avatar
Wiki Edits: 16
With all due respect, that is like calling the phone company and saying, "you choose the plan that is best for me," or asking a used car salesman to "pick whatever car he thinks is best."
They will provide all kinds of tech info to steer you into the polished 9000000 CFM wonder carb that is the newest thing.
Old 09-23-2008, 05:33 AM
RippinRon's Avatar
Ford also used a q-jet on the 429 SCJ!
Old 09-23-2008, 09:33 AM
Rustydawg's Avatar
Yup, you could get a guy that tries to shyster you into an expensive carb that you don't need. You take that chance. My experience is that the tech folk on the phone is a tech folk, not a salesman.
I would bet that the customer gets themselves in over their head on camshaft or carburetor choice more times than can be blamed on the tech support fellow. They're not on commission.
Calling a mail order warehouse may be a different matter. I would steer one towards the manufacturer's 1-800 support.
Old 09-23-2008, 10:56 AM
curtis73's Avatar
Wiki Edits: 16
Yeah, that's true. I've just been shocked before at tech lines and their non-commissioned advice. I once had a guy at PAW tell me that all GMs used the same distributor and then tried to convince me that buying a chevy distributor would work in my Caddy 500. Then he went on to say that BBCs had a different cam gear because they were reverse rotation.
I didn't even say goodbye, I just hung up.
Old 09-28-2008, 02:46 PM
Thanks guys!!
Doesn't that depend a lot on what combination of parts you are building, for what overall purpose, and what specific vehicle it is going into?????
I would only use an air valve secondary, regardless of brand name.
Old 09-28-2008, 04:40 PM
OHD's Avatar
OHD OHD is offline
" I once had a guy at PAW " YA GETS WHAT YAS, PAY FOR
Try AED they are good and build every single carb in house.
Old 09-29-2008, 10:29 AM
Technical Support Barry Grant
Thanks guys!!
How much duration at .050 does the cam have? WHat transmission? If you want to pm us some more engine details we will be glad to make a recommendation for you. Typically with the 347 engines we are using a 650 on them for reference.
Old 09-29-2008, 10:32 AM
You won't get that with our guys. Our tech guys are not tied to the sales department and will look at the engine and vehicle combination and make a recommendation based on information that can be found on our web site.
Quadrajet Carb??????? zbhover Engine 15 08-26-2010 08:57 AM
backfire thru carb airraptor Engine 11 06-12-2009 02:30 PM
700 R4 tv cable hook up at carb murrsue Transmission - Rearend 4 10-18-2006 09:50 AM
Cleaning Carb Question oldcarguy36 Engine 17 03-04-2006 02:10 PM
Holley carb has me at wit's end cool rockin daddy Engine 23 06-02-2005 02:38 PM
