carb 760cfm vac secondary - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-26-2007, 10:15 PM
i just got this carb and having a little problem when i fist take off with it i have a little bog what can i look for they say they are all set to run lol. it is on a 355CID chev motor. the motor is not stock thank you for the help
al nat
Old 03-26-2007, 10:31 PM
T-bucket23's Avatar
Wiki Edits: 26
Make sure there is no play in the accel pump arm. It should be touching while the throtle is closed. With the throttle wide open you should be able to move the lever so there is at least .015 clearance between the lever and the arm. there are a lot of things that can cause bog. There are also several threads on here dealing with it and a lot of info on the Holley site
Small changes are the key to carb tuning.
Old 03-26-2007, 10:41 PM
T-bucket23
thank you very much i will try that
al nat
Vacuum advance western star Engine 14 11-30-2009 11:28 PM
Holley Carb. Question crusherdbuzz Engine 2 07-02-2006 04:25 PM
Holley carb has me at wit's end cool rockin daddy Engine 23 06-02-2005 03:38 PM
rochester 4 jet carb, rich Walker Engine 2 07-13-2003 10:42 AM
Holley carb & powervalve info Frisco Engine 9 06-25-2003 02:47 AM
