Carb Adapter - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-15-2004, 05:22 PM
Erk Erk is offline
Carb Adapter
I have a Professional Product RPM airgap and its SQUARE BORE.
Now i am getting a Holley 650cfm spreadbore.
I cannot find a square bore 650 vacuum for the life of me..So does an adapter work as a spacer also or is it just an adapter?
-Eric
Old 03-15-2004, 05:51 PM
lluciano77's Avatar
Short changed on common sense
The adapter is a one inch spacer.
Holley just recently started making their squarebore 650 vacuum secondary carb. Why not use an 1850, 600 CFM carb?
Or get a 750 vac. sec. How do you know 650 is the right size?
Old 03-15-2004, 06:13 PM
Erk Erk is offline
I did the calculations and i need around 615cfm..but that doesn't mean anything..My best friend has basically the same setup and is running a 650 and runs good but might be able to go to a 750.
Setup is 9.5:1 compression 360-375(EST) chevy 357(.040).
Another thing is i am having trouble with finding an adapter from spread bore to square bore. All i can find is square bore to spread bore intake.The performer RPM airgap is a square bore intake so thats why i need it..If you have any other suggestions/carbs it would be appreciated.
-Eric
Old 03-15-2004, 09:02 PM
poncho62's Avatar
Wiki Edits: 5
Flip the adapter over.......................
Adapters are notorious for giving carb problems....should avoid them, if possible.
Ontario Rodders
Old 03-16-2004, 02:44 PM
Erk Erk is offline
I could avoid it by going with the 650 Double Pumper route which is square bore.I only have $150 to spend on a carb(rebuilt).
-Eric
Old 03-16-2004, 05:07 PM
lluciano77's Avatar
Do not follow that formula. That formula does not work for performance vehicles.
I am sure you could run a vac. 750 or a 650 DP with no problems.
Old 03-16-2004, 07:31 PM
rifraf's Avatar
I would rather have one a little small over a mis match with a spacer,at least it would run good and have good response.
Old 03-16-2004, 10:06 PM
lluciano77's Avatar
If it is making 360 to 375 hp, a 650 CFM DP would be conservative.
Old 03-16-2004, 10:35 PM
FiveFeezy's Avatar
Fishing poles in the hot rod!
I would use the adapter as a temporary thing until you can get a good square-bore holley. I used an adapter once and my motor ran fine. But when I finally got a carburetor that didn't need an adapter the motor ran a lot better at the top.
Old 03-18-2004, 04:52 AM
rifraf's Avatar
Conservative puts your shoulders in the seat all the way threw,not just begging for a high rpm rush with an indecisive screwdriver. Adapters are indecisive.
