Carb adapter help - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-01-2008, 11:53 AM
Last journal entry: more work
Carb adapter help
Friend at work asked me to help him find (if they even have one) an adapter to go from a V6 throttle body manifold to a 4 barrel quadrajet . I havent had much luck, but thought someone here may have an idea. We have access to a mill and such so we can probably fabricate one if we really have too.
He blew his carberated 4.3 and has another 4.3 complete but its TBI. The manifolds aren't interchangeable and he is cheap soo this is where we are at.
Old 08-01-2008, 05:15 PM
Wiki Edits: 31
IIRC the 4.3 replacement would be a Vortech engine, if the heads off of the original carb'd 4.3 are ok, he could swap them on along with the manifold, and it will work ( compression ratio will be low, but it will run ). otherwise GMPP has the Vortech 4bbl manifold, available from the dealer.... the adaptor you want is likely not available
Old 08-01-2008, 09:12 PM
I believe there are so few people who would actually want to use a quadrajet that the market for such an adapter would be extremely small. I suggest looking at other alternatives.
Old 08-01-2008, 10:01 PM
345 desoto's Avatar
Location: Skaneateles, NY Summer/Port St.Lucie, FL Winter
I went through the same thing mateing up a Ford 65mm TB to a spreadbore intake. What I did was use one of those 1", open center, aluminum carb spacers with the square bore/spread bore bolt hole patterns. TIGed the TB to it and it did the trick. I imagine you might be able to do the same thing with one of those Quadrajet to Holley bolt pattern spacers, and turn it upside down...
modifying that too rich edelbrock 1405 carb? TVR383 Engine 23 12-03-2009 10:19 PM
Lincoln 4.6 carb adapter 32chevy vett Hotrodders' Lounge 3 06-10-2008 09:16 PM
Cleaning Carb Question oldcarguy36 Engine 17 03-04-2006 03:10 PM
Holley carb has me at wit's end cool rockin daddy Engine 23 06-02-2005 03:38 PM
edelbrock carb Vacuum problem? 75400truck Engine 16 10-03-2004 10:29 PM
