carb adjustment
1K views 0 replies 1 participant last post by  max7276
i might be misunderstanding this but I need help adj. my Holley 670 street avg. carb on my engine that is a small block 350 bored .030 over with a comp cams 292-h camshaft everything throughout the valve train matches this camshaft. I am at aproxiamatly 1000 feet above sea level. dual feed single pump vac. sec.i havent got into the carb to see what the jet size is.And it has an automatic trans behind it with a 2800 stall converter. Any help in how to set this carb up and adj. would be very helpful tks.
