After digging through this & several other forums, I see the question comes up a lot & the answers are very sketchy. After hunting for images, I found a picture of the proper setup...which set off a light bulb in my head:
Once you see it installed, its very simple. Detent cable sits on that bottom horn of the throttle linkage next to where the return spring mounts, so when the throttle is pulled back, it pulls the kickdown forward. I looked again at the picture of the carb on eBay & its got a hole there for a stud, so I think we're good to go. I went ahead & ordered it. Thanks for all the help as always guys!! Wish me luck.
hey guys, hate to revive an old post but I figured it made more sense than starting a new one up...that carb from ebay came in the mail & it looks like everything should be good but I have a question on installing it...
Vacuum lines...with the old Carter carb, the distributor vac advance connected to a small port on the front of the carb, the PCV connected to a big port on the front, and the brake booster connected to a big port on the back. The Holley doesn't have the same vacuum ports though. Just a small vacuum port down by the mounting flange, a small port on the front bowl & a big port by the rear bowl...so what goes where? |
For the P/B, you can use a port plumbed to the intake itself. |
| What's the best carb & fuel tank replacement for a 1955 Chevy 235 straight six? | islandman | Engine | 5 | 09-17-2011 10:50 PM |
| Carb issues, advice needed | DeputyDawg134 | Engine | 6 | 12-11-2007 12:42 PM |
| 700 R4 tv cable hook up at carb | murrsue | Transmission - Rearend | 4 | 10-18-2006 09:50 AM |
| I'm going to make a bonfire out of my car | blown69stang | Engine | 36 | 08-22-2005 03:36 PM |
| Need some pointers on Holley carb | crshrmn3 | Engine | 2 | 02-08-2003 11:22 PM |
