Carb advice
Got a new bullet going in the 71 c10 weekend driver/cruiser a need some carb advice here are the specs thanks...
Edelbrock Performer RPM intake, 1" spacer, HEI distributor, MSD plug wires, fully rebuilt heads with new valve springs, new seals,10 degree locks, retainers and lash caps, stainless steel valves (2.25I 1.88E), full roller rockers, JoMar stud girdles, new Comp Cams xm 278h-565 lift-234/244 dur @ .50 , lifters, and timing chain, forged SpeedPro pistons, ARP main studs, new head bolt kit, new bearings, new rings, Melling oil pump, fabricated aluminum valve covers, FelPro gaskets, stainless steel bolt kit,flowtech headers. |
Big- I'm guessing it's a 454 (?). If so, with 100% VE, and that you want to spin some pretty good rpm (I figured 6200 max) it'll need about 825 cfm.
Sorry should have said what engine at the start it is a 468 bbc...So should I go with a holley or quick fuel I live about 20 min from qf
as per Holley's carb selector this is what it came up with using 468, 6000rpm max, vaccum secondaries, and manual choke
http://holley.com/0-81870 |
| Hi, I need advice on intake/carb | Juicer28 | Engine | 2 | 02-16-2012 07:00 AM |
| Carb Advice | 65malibuSS | Engine | 3 | 12-21-2010 11:44 AM |
| Hi all I took your carb advice to heart need to know a little more | ghomer | Engine | 18 | 09-05-2010 06:58 AM |
| carb advice | Bill-E-BoB | Engine | 17 | 03-28-2010 07:19 PM |
| need carb advice | jjpodlas | Engine | 8 | 01-03-2009 08:53 AM |
