carb ajustment - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-09-2008, 06:07 PM
carb ajustment
my S10 started runing rich 350 sb its been setting for a while so im hoping its just needs a carb ajustment holley 4160 or maybe a rebuild, ill try fresh gas too, any ideas ohh it's pretty bad if you set in it, or stand behind it, it'll make your eyes water
Old 06-09-2008, 09:02 PM
Check the float leval and the power valve. If it all of a sudden started running rich I would look at both of them first.
Old 06-09-2008, 11:24 PM
JeffB's Avatar
The older Holleys would puke a power valve with one backfire thru the carb, the newer power valves have an upgrade to prevent this,change it for sure.
Demon or Holley Carb for 306 Ford? Dino Boreanaz Engine 10 12-09-2006 06:04 PM
700 R4 tv cable hook up at carb murrsue Transmission - Rearend 4 10-18-2006 09:50 AM
Holley Carb. Question crusherdbuzz Engine 2 07-02-2006 03:25 PM
Holley carb has me at wit's end cool rockin daddy Engine 23 06-02-2005 02:38 PM
Need some pointers on Holley carb crshrmn3 Engine 2 02-08-2003 11:22 PM
