Carb and Alt question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-19-2010, 07:24 AM
My one rochester quadrajet died on me yesterday. Saturday the car ran but i took it for a ride and when I got on it, it seemed like it wasn't getting enough fuel because it would die out and then idle. i came back and parked it until yesterday when I replaced the fuel filter in the carb and the in line clear one I have installed. NOTHING.... The car won't start and there is fuel right to the carb. I tried it without the carb filter, still nothing. Changed the carb and the car purrs like a kitten. What could be wrong? Could dirt have clogged the carb up completely? I tried blowing it out with compressed air.
ALSO....
I have a 3 wire alt and had it wired to work on 1 wire. The way I have it wired is one wire from the battery (via the starter) to the main terminal, then a line from the main terminal to one of the other two prongs. Is this the correct way? My car is not charging anymore. I have to make sure a wire didn't come loose but the car cranks fine and I have 12v (same as battery voltage) at the alternator so I doubt any did.
Old 04-19-2010, 08:12 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by maxpower_454
the car won't start and there is fuel right to the carb. I tried it without the carb filter, still nothing.
See if the carb is dry- you can tell easily by working the throttle while watching for the accelerator pump discharge- choke open so you can see. If there's NO fuel, the needle/seat has clogged. You can clear it (at least temporarily) by removing the fuel line and CAREFULLY blow pressure into the fuel port. DO NOT use compressor line pressure! If you do, all hell will break loose inside the carb and the float arms can be bent, etc. Just a gentle blow through it will probably dislodge whatever's clogging it.
If this doesn't work, or if you want a permanent fix, take the top off, and clean it out. Recheck the float level (~1/4", measured w/the "D"-clip held firmly in place, and at the mark across the toe of the float).
Does it have a voltage regulator compatible w/the 1-wire set-up? The 1-wire deal isn't particularly good, I wouldn't use it, personally.
Old 04-19-2010, 09:45 AM
Blowing it out with air didn't clear it so I guess I'll have to tear it apart. Where can I get a rebuild kit for a quardajet?
These questions are regarding my dirt track car that i race in a stock class. The common trick is to wire a 3 wire alt to work on 1 wire. I thought maybe some guys on here knew how to do this.
Old 04-19-2010, 10:05 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
AFA the 10 SI wiring goes, it's just a jumper from the "2" to the "BATT" terminal. The VR has to be self exciting.
Old 04-19-2010, 11:18 AM
sbchevfreak's Avatar
Licenced Automotive Technician
You need to have a momentary 12v to the light pin on startup, plus the jumper to the other pin. These will lose "residual magnetism" without that feed.
Old 04-20-2010, 05:20 AM
Not sure what you mean by that Whic pin is #1 and 2? Which is the light pin?
Old 04-21-2010, 06:46 AM
Old 04-21-2010, 04:33 PM
You need momentary voltage to the other pin. You have a battery wire to the main lug, then one from the main terminal to the field pin, and there is only one left. It needs a momentary 12v to "wake up." I ran into this alot on oilfield engines. Everything oilfield I worked on had a delco 10si alternator on it, and I had to add this momentary feed to many, many of them. I used either a diode and a wire from the start wire, or a relay energized by the start wire. Either works, but the diode wire is simpler to wire, and less expensive. If you don't do a diode/relay, as soon as the engine starts, 12v goes back to the start terminal on the starter, and trys to engage it while the engine is running.
Old 04-21-2010, 05:27 PM
http://www.madelectrical.com/electri...esensing.shtml
Old 04-23-2010, 08:09 PM
So if I just hook a diode from the pin that is connected to the main terminal (and battery) to the empty terminal it should work? Obviously I need the diode facing the right way but I can handle that
Old 04-26-2010, 06:10 AM
Anyone??????????
Old 04-26-2010, 07:11 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If you have a self exciting regulator, usually a quick rev of the engine is enough to kick start the alternator.
A one wire alternator will not 'kick off' below around 1500 RPM ordinarily (and could be higher), so you might want to look for a smaller (overdrive) pulley if this becomes a problem.
Once the alternator is started, it will remain active until the engine is shut off, regardless of RPM.
Good luck.
Old 04-27-2010, 06:57 AM
I don't have a 1 wire alt, I have a 3 wire. I tried touching a wire from the empty pin to the battery terminal momentarily and the alternator still did not start charging. Nothing happened. I will try a diode this weekend but I don't this will be any different. Am I missing something? here's a little diagram of what i plan on doing. Is this correct?
Old 04-27-2010, 12:52 PM
ANyone????????????????
Old 04-27-2010, 04:28 PM
if you tried the alt like that and it doesn't work, its likely NFG
Alt Gauge Reading dcpky Electrical 1 11-02-2008 10:02 AM
From EFI to carb on a 5.0? Fat_46 Engine 5 06-28-2005 01:06 PM
fuel inj-to- carb swap,HELP!! handyman Engine 3 09-21-2004 09:30 PM
