Carb bog vs timing issues? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-31-2012, 11:40 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
With the combo that you have I am fairly sure that you have the correct carb now..Tuning that carb to get the bog out can be done for sure..just takes a bit of noodling to get it adjusted correctly so when you hit the gas you no longer have that soft spot. I still think the secondaries are opening just a wee bit too soon giving you that what you say is a bog..I would for sure look into the tuning before throwing a bunch of $$$$$$$$$$ at it..
Sam
  #17 (permalink)
Old 12-31-2012, 02:10 PM
Hacksaw's Avatar
BOOMER SOONER
Sam
I've only got about 150 miles on this engine so far. It runs good, and I do plan on a gear swap soon. But for now, it's what I've got. I'm sure Patrick set the carb up right, and I did submit a much lower gear to him to build it. I'll call him after they get back from the holiday and see what he recommends. In the mean Time, I plan on messing with the timing, and curve to help out some. I don't want to put money into tuning that Edelbrock 600, since I'm not going to be using it anyway. Just a waste of $$! I can live with that slight soft spot to put some break in miles on it. Thanks for all the input. I just mainly wanted to know if I would mess anything up by running it as is.
  #18 (permalink)
Old 12-31-2012, 02:48 PM
Wiki Edits: 3
I cannot see how it will hurt anything to run it as it is..I would say that you may be gettign the bog in part throttle operation and if you were to get on it hard the bog may not be there at full throttle..carbed engines will act like that sometimes..
Sam
  #19 (permalink)
Old 12-31-2012, 05:07 PM
Hacksaw's Avatar
BOOMER SOONER
Thanks everyone for the input. I still can't believe I went from a frame up resto mod 70 Chevelle with carbed LS1 conversion with muncie 21 and built 12 bolt 4.10:1 and moroso posi unit that burned up in a wild fire, to a stock 80K miles restored 70 Malibu sport coupe that I bought the crate engine for, and ended up having 2.56:1 peg leg 10 bolt!!!
Carb/timing issues Pops59 Engine 2 04-25-2011 09:34 PM
timing issues...please help theV8man Engine 15 06-15-2010 11:39 AM
HELP!!! Bad bog and 50 degrees total timing? Eagle1 Engine 38 06-29-2008 05:00 PM
Timing issues i think Wmurp4 Engine 4 08-13-2006 04:27 PM
timing issues Ferox Introduce Yourself 1 10-07-2004 08:04 PM
