Are our secondaries coming in just a skosh too soon..a bog can be a sign of over carbed,,too much carb for the engine to absorb at a particular rpm..
Sam
That would sure suck. This engine is a Year One Power Crate 350 with the Edlebrock E-Tech heads and Performer RPM intake. 9.7:1 compression, hyd roller. 413 hp 444 tq is what is on the dyno sheet. I submitted the entire engine specs from the paperwork I got with the engine, vehicle info, with exception of the rear gear which changed after the carb was built. I believe this carb is a 780 cfm.
All that is needed I think is an adjustment in the timing of the secondaries,,A tuning issue..
Sam
I put a couple more degrees in for a total of 40, which I think is too much, but it still starts and dies fine, has no ping, and carb smoothed out quite a bit. So, now I'm wondering how much is too much timing? Maybe a combo of ignition and carb timing?
The DP carb will want a lot lot lot more rear gear ratio.
The distributor mechanical advance curve needs a lot of work. Not enough inital at idle. You want 24-26deg at idle 34-36deg at max advance a 10deg advance curve. Your MSD distributor requires a sepecial $33 distributor advance stop bushing to achieve the required timing curve. If you must use a 2.56 gear ratio get a vac sec carb. 600 to 750cfm vac sec holley or 600-750 edelbrock. The double pumper will work if you get a agreessive rear gear and a high stall converter. 4.10's and a 10" 3500 stall if you want to go fast. The bushing to set up the distributor timing curve is found here http://www.4secondsflat.com/MSD%20Di...r%20Tuning.htm Last edited by F-BIRD'88; 12-30-2012 at 07:01 PM. |
The info here was originally on the GM HEI but the timing info applies universally. Get the timing sorted out first then concentrate on the carb tuning. Readjust the idle mixture screws for highest vacuum/fastest idle rpm as you work on the timing but leave the other carb circuits alone until the timing is done. You might need to add duration to the accelerator pump(s). This is done with either a pump cam change, or to a smaller shooter. More on tuning the Holley accelerator pump here. Good luck. |
If you just mat the gas from a stand still or at lower rpm, it may bog because of the gears.
But if the bog is there when the carb transitions into the secondaries- even w/the engine up into the powerband- then there's a problem or problems that need to be addressed. The carb size needs to be verified, too. |
| Carb/timing issues | Pops59 | Engine | 3 | 04-25-2011 08:34 PM |
| timing issues...please help | theV8man | Engine | 15 | 06-15-2010 10:39 AM |
| HELP!!! Bad bog and 50 degrees total timing? | Eagle1 | Engine | 38 | 06-29-2008 04:00 PM |
| Timing issues i think | Wmurp4 | Engine | 4 | 08-13-2006 03:27 PM |
| timing issues | Ferox | Introduce Yourself | 1 | 10-07-2004 07:04 PM |
