Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - carb choice
Thread: carb choice
Old 08-10-2003, 08:38 PM
2wld4u 2wld4u is offline
WV hillbilly
Last journal entry: PTL 220CC
Re: carb choice
Originally posted by jonathan stout
for this motor combo, would the 825dp be better than the 750 dp? BG Mighty Demon./406, 220cc pro 1 heads,full roller rockers,petronic ign.,holley race pumpw/regulator,windage tray oil pan,. 6qt. capacity. @50 230 duration, rpm air-gap, th350 posi 3.73
I would say yes, but.....Id try a 2" spacer berfore I bought another carb...and if you do run a spacer be sure to jet your carb a little ritcher...IE: read plugs...but, If you ever decided to go with a single plane, or plan to, Id stay with the 750...
