Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - carb choice
Thread: carb choice
Old 08-11-2003, 10:07 AM
78SilverShark 78SilverShark is offline
Vetter
Re: Re: carb choice
Originally posted by 2wld4u
I would say yes, but.....Id try a 2" spacer berfore I bought another carb...and if you do run a spacer be sure to jet your carb a little ritcher...IE: read plugs...but, If you ever decided to go with a single plane, or plan to, Id stay with the 750...
Why would you want to use a spacer? I heard that spacers only put the power up at a higher RPM. And if you are using this on the street, that isn't really a desirable thing.
