-   -   carb choice (http://www.hotrodders.com/forum/carb-choice-21063.html)
jonathan stout 08-10-2003 02:47 PM
carb choice
for this motor combo, would the 825dp be better than the 750 dp? BG Mighty Demon./406, 220cc pro 1 heads,full roller rockers,petronic ign.,holley race pumpw/regulator,windage tray oil pan,. 6qt. capacity. @50 230 duration, rpm air-gap, th350 posi 3.73
2wld4u 08-10-2003 09:38 PM
Re: carb choice
I would say yes, but.....Id try a 2" spacer berfore I bought another carb...and if you do run a spacer be sure to jet your carb a little ritcher...IE: read plugs...but, If you ever decided to go with a single plane, or plan to, Id stay with the 750...
Tech @ BG 08-11-2003 10:10 AM
A 750 would be a better choice on your combination.
78SilverShark 08-11-2003 11:07 AM
Re: Re: carb choice
Why would you want to use a spacer? I heard that spacers only put the power up at a higher RPM. And if you are using this on the street, that isn't really a desirable thing.
Tech @ BG 08-11-2003 11:52 AM
If you use an open plenum spacer it will decrease the low end torque/response, and give you more top end power. You can use a 4-hole spacer to actually increase the lower end response and torque.
78SilverShark 08-11-2003 02:21 PM
But what would this 4 hole spacer do to the top power (5k RPM)? Just sqeeze it out, or maintain?
Tech @ BG 08-11-2003 02:23 PM
A 4-Hole Spacer would move the power band down a few hundred RPM.
78SilverShark 08-11-2003 02:27 PM
Which would be good for a street car. But, wouldn't be good for my Vette. I already have low end power. But I would see the use of it.
jonathan stout 08-11-2003 06:30 PM
carb
carb choice not spacer. i have yet to buy either.
2wld4u 08-11-2003 09:21 PM
using a spacer kinda acts like using a bigger carb, (more plenum volume to draw from) and thus more air, this is why you may have to jet your carb ritcher (your getting more air) if your car responds well to the spacer then it may be ok to go with a bigger carb, if it doesnt then you may want to stick with what you have...a dual plane intake always likes a bigger carb that say a single plane..a new carb costs hundreds and a spacer? about 30 bucks...and FYI, spacer's are a great way to fine tune performance..(if needed)
1BAD80 08-12-2003 08:00 AM
DITTO: with 2wld4u and Tech @ BG
jonathan stout 08-13-2003 09:35 AM
carb
the only carb i have now is a 6oo vacum sec. carb. and it is for sell because im sure that it wouldn't work. any more suggestions on 750/825 BG MIGHTY DEMON?
Tech @ BG 08-13-2003 10:00 AM
Carb Choice
The 750 Mighty Demon P/N 5402010GC would be you're best choice on your combination.
jonathan stout 08-13-2003 08:19 PM
thanx tech
