carb choice - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-10-2003, 01:47 PM
New Member
carb choice
for this motor combo, would the 825dp be better than the 750 dp? BG Mighty Demon./406, 220cc pro 1 heads,full roller rockers,petronic ign.,holley race pumpw/regulator,windage tray oil pan,. 6qt. capacity. @50 230 duration, rpm air-gap, th350 posi 3.73
Old 08-10-2003, 08:38 PM
WV hillbilly
Last journal entry: PTL 220CC
Re: carb choice
I would say yes, but.....Id try a 2" spacer berfore I bought another carb...and if you do run a spacer be sure to jet your carb a little ritcher...IE: read plugs...but, If you ever decided to go with a single plane, or plan to, Id stay with the 750...
Old 08-11-2003, 09:10 AM
Technical Support Barry Grant
A 750 would be a better choice on your combination.
Old 08-11-2003, 10:07 AM
Vetter
Re: Re: carb choice
Why would you want to use a spacer? I heard that spacers only put the power up at a higher RPM. And if you are using this on the street, that isn't really a desirable thing.
Old 08-11-2003, 10:52 AM
If you use an open plenum spacer it will decrease the low end torque/response, and give you more top end power. You can use a 4-hole spacer to actually increase the lower end response and torque.
Old 08-11-2003, 01:21 PM
Vetter
But what would this 4 hole spacer do to the top power (5k RPM)? Just sqeeze it out, or maintain?
Old 08-11-2003, 01:23 PM
A 4-Hole Spacer would move the power band down a few hundred RPM.
Old 08-11-2003, 01:27 PM
Vetter
Which would be good for a street car. But, wouldn't be good for my Vette. I already have low end power. But I would see the use of it.
Old 08-11-2003, 05:30 PM
New Member
carb
carb choice not spacer. i have yet to buy either.
Old 08-11-2003, 08:21 PM
WV hillbilly
using a spacer kinda acts like using a bigger carb, (more plenum volume to draw from) and thus more air, this is why you may have to jet your carb ritcher (your getting more air) if your car responds well to the spacer then it may be ok to go with a bigger carb, if it doesnt then you may want to stick with what you have...a dual plane intake always likes a bigger carb that say a single plane..a new carb costs hundreds and a spacer? about 30 bucks...and FYI, spacer's are a great way to fine tune performance..(if needed)
Old 08-12-2003, 07:00 AM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
DITTO: with 2wld4u and Tech @ BG
Luv the smell of NITRO in the morning.
Old 08-13-2003, 08:35 AM
New Member
carb
the only carb i have now is a 6oo vacum sec. carb. and it is for sell because im sure that it wouldn't work. any more suggestions on 750/825 BG MIGHTY DEMON?
Old 08-13-2003, 09:00 AM
Carb Choice
The 750 Mighty Demon P/N 5402010GC would be you're best choice on your combination.
Old 08-13-2003, 07:19 PM
New Member
thanx tech
