carb choice - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2005, 06:52 PM
75sprintguy's Avatar
Last journal entry: a good used 350 we installed
carb choice
wich do yall prefer
Old 06-29-2005, 09:27 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Mounts
Need a little more detail ...
Well, I've always been partial to British Zenith updrafts myself ... NOT!
Seriously ... ASSUMING that you mean the "usual" 4-BBL aftermarket carbs ... I like Holleys.
There are a ton of them out there, parts are plentiful, and they are relatively simple to disassemble / re-assemble. I'd recommend one that has the dual inlet center-pivot float bowls, because the single-inlet with a transfer-tube style causes most folks a lot of stress.
On the other hand, though, most mechanics that I talk to seem to prefer Carter AVS or AFB carbs. I am considering one of Edelbrock's Thunder AVS (Carter Style) for my current project (Chevy 454 in a 1966 GMC).
http://www.edelbrock.com/automotive_...ess_main.shtml
I scares me a little to see that these are being built by Magnetti Macaroni though. They were the guys that built some really odd-ball alternators on agricultural equipment, and I used to shudder a little every time some old farmer brought one in for testing / repair!
Don
Old 06-29-2005, 09:29 PM
lluciano77's Avatar
Short changed on common sense
The Holley model 4010 hands down. I'd take mine over a BG or 4150 any day.
Old 06-30-2005, 06:23 AM
Technical Support Barry Grant
Which Carbuiretor?
As far as performance goes I'll put a Demon up against anything.
Old 06-30-2005, 07:42 AM
MI2600's Avatar
Member# 3287
Nothing beats the Tillotson!
Old 06-30-2005, 07:46 AM
tornado-tech's Avatar
I have ran just about every kind of carb and the easiest I ever have had to tune was a Demon. They all extremely close out of the box but you do pay for this. The Holleys are good but require a lot more tuning which in the long run come very close to costing what you pay for a Demon when you figure in the parts and your time.
Old 06-30-2005, 08:14 AM
Rhansen's Avatar
Footbraker
I recommend that all the competition use a holley 1850.
Old 06-30-2005, 09:45 AM
Canadian Charlie's Avatar
The Big Money
Last journal entry: New Air Line Part 2
I like the Holley carbs, easy to tune. I'm on my second Holley now a 750 double pumper. Had a 650 Vacuum secondary on my old 69 Chevelle
Holley carb has me at wit's end cool rockin daddy Engine 23 06-02-2005 02:38 PM
Need help with Edelbrock carb Crazy-J Engine 1 06-01-2005 02:24 PM
Carb choice for 177 blower hectic Engine 1 07-15-2004 11:38 AM
carb choice jonathan stout Engine 13 08-13-2003 07:19 PM
carb choice,..not spacer jonathan stout Engine 0 08-11-2003 04:57 PM
