-   -   Which Carb to choose (http://www.hotrodders.com/forum/carb-choose-226784.html)
prettyboyced 12-03-2012 04:34 PM
I have a sbc 355 with afr 190s xfi280 Cam 230intake 236 exhaust .570 .576 lift rpm air gap intake 600 edelbrock carb with turbo 350 3500 stall and 3.73 gears so I wanted to get a better carb like 650dp or 750 I don't really care bout gas milage or should I just get my carb redone
techinspector1 12-03-2012 06:01 PM
Holley Model 4150 HP Carburetors 0-80528-1 - SummitRacing.com
ap72 12-03-2012 06:57 PM
Assuming you have a heavy car or an auto trans I'd go with a Vacuum Secondary carb- NOT a double pumper.
Here's a good Vac secondary carb: Demon Carburetion Speed Demon Carburetors 1563010VE - SummitRacing.com
prettyboyced 12-03-2012 08:11 PM
Yes it's an 86 Monte Carlo ss
F-BIRD'88 12-03-2012 08:40 PM
A 750HP double pumper will work the best. You can build one using any 650-700-750 DP and the holley or proform HP body upgrade kit. This is the carb you need.
vinniekq2 12-03-2012 10:29 PM
750 double pumper would be an excellent choice.
Ive used 600 double pumper/750 and 850 on my old camaro and also used 2X750 carters on a 355 street car.The worst was the 600 double pumper,the 750 was the easiest drive,it just works at every RPM
prettyboyced 12-04-2012 01:03 PM
Is the 750hp double pumper worth the extra money or can I get the regular double pumper 750
vinniekq2 12-04-2012 01:09 PM
the 4779 doesnot have removable air bleeds.Are you planning on doinga detail tune job on the car? Have you tried the carb shop? talk to Pat
xxllmm4 12-04-2012 01:46 PM
I'll probally never use anything else again. These are basically made for your combo. All I had to do was adjust idle and go. Jetted perfect out of the box.
PRO SERIES 4150
