Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Carb conversion ?
Old 01-30-2013, 02:02 PM
33Willys77's Avatar
33Willys77 33Willys77 is offline
Just a suggestion, but to make good carbs and make them work correctly, have someone that knows these things in and out work on them - or send them in to one of the several good carb companies to rework them. Make sure you have good carbs on that blower - a lean condition will cost $$$$. Should really only need blocks, jets, power valves (to suit your engine) and boost reference them. You can get these parts from carb builders too (such as Quick Fuel). Call one of them - they can tell you what you need if you prefer to do it yourself - and possibly buy the parts from them.
