carb enclosures??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-19-2002, 07:11 PM
chevyelc81's Avatar
Post carb enclosures???
When you run a supercharger(blow through type), do you have to run a carb enclosure that encloses the entire carb, or can you run hosing that bolts in place of where the air filter would normally go? I thought you had to run an enclosure, but I saw a supercharged car in a magazine with the carb exposed. Is there a special carb??? any info will help. thanx <img src="graemlins/drool.gif" border="0" alt="[drool]" />
Old 11-19-2002, 07:14 PM
BOBCRMAN@aol.com's Avatar
Post
you can run them either way ,its easier to use an enclosure. you have to seal the throttle shafts and minor mods if you blow thru.
Old 11-19-2002, 07:16 PM
woodz428's Avatar
Troll Hunter
Post
Yes you do , there are more complex ways around it but the enclosure is the most effective solution. What you are doing is pressurizing all the circuits in the carb, without some sort of pressurization when the blower gets up on boost it will blow the fuel back through the jets because the fuel bowls aren't pressurized. That's the short explanation. Ford used the blow through without the bonnet in the mid fifties, the difference was the fuel bowls were on top of the carb thereby getting pressurized.
Old 11-20-2002, 06:52 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
[quote]Originally posted by woodz428:
<strong>Yes you do , there are more complex ways around it but the enclosure is the most effective solution. What you are doing is pressurizing all the circuits in the carb, without some sort of pressurization when the blower gets up on boost it will blow the fuel back through the jets because the fuel bowls aren't pressurized. That's the short explanation. Ford used the blow through without the bonnet in the mid fifties, the difference was the fuel bowls were on top of the carb thereby getting pressurized.</strong><hr></blockquote>
NO, this is not correct! You do not have to run an enclosure and the modifications are the same to the carb with the exception of sealing the throttle shafts if you just use a bonnet. This is not even an absolute. Alot of turbo guys just use a bonnet with no throttle shaft seals. On a new holley there is little leakage.
Additionally, whether in an enclosure or not the fuel can be pushed back out of the bowls if boost pressure exceeds fuel pressure. This is why a boost referenced fuel regulator is manditory. You set it at the normal 7 psi and it raise the fuel pressure at the rate of the boost increase. This means you must run a high pressure pump. If you are going over 10 psi, a fuel injection pump is necessary to make enough pressure.
For more information on this stuff check out <a href="http://groups.yahoo.com/group/blowthruturbo" target="_blank">this</a>list on yahoo. There is a wealth of information on this stuff.
Chris
Old 11-20-2002, 08:26 AM
chevyelc81's Avatar
Post
Thanx alot for the info, this really helps. So if I buy a brand new holley carburator, I will be safe with just the bonnet, and no carb enclosure??
What about your power brakes, and vacuum advance, etc?? Where do you put these?
Old 11-20-2002, 11:20 AM
TurboS10's Avatar
Wiki Edits: 2
Post
Power brakes can be a bit of a problem. They will work under normal driving conditions, but under boost you could use a check valve to keep the brake booster from working backwards. Best bet is a manual setup.
Vacuum advance, kindof the same issue. Most guys just eliminate it. Usually on a boost application timing retard is more important than advance. Make sure you get a BTM module.
Chris
Old 11-21-2002, 03:21 PM
woodz428's Avatar
Troll Hunter
Post
The Paxton conversion that was offered in the '60's( by Shelby as well as Paxton) used the enclosure and it is much simpler than sealing the throttle shafts since they are in the box they don't require sealing. Yes if you get too much boost the fuel will blow back through the jets even with the enclosure if a pressure sensor line isn't used. Another way is to have a pressure switch to activate an electric pump to keep the pressure up, anything over 8-10 pounds boost is really unneccesary for a street engine.
Old 11-21-2002, 08:52 PM
TurboS10's Avatar
Wiki Edits: 2
Post
Quite a few ford guys are running 18 psi turbocharged street engines on pump gas. Nasty little buggers....You dont want to challenge one of them to a street competition.
Chris
Old 11-22-2002, 09:29 AM
chevyelc81's Avatar
Post
I bet useing an enclosure is fun to tune...you have to remove it everytime you want to make an adjustment... Would I be safe with a new holley and a bonnet?? Ill probably use a max of 8psi boost. Or should I just be safe and get an enclosure?
Old 11-22-2002, 03:49 PM
woodz428's Avatar
Troll Hunter
Post
Jusr because you run 20 lbs boost ( I know it's done)on the street doesn't, for me, make it a street car. I've run many unstreetable cars on the street in my life, but would never reccomend someone else build them, a 5:14 gear on the street is quick but makes a crappy street car. The adjustments aren't that bad ,most enclosures I've used are 2 parts, the top comes off for adjustments and if I recall correctly they have holes for idle mixture and such.
