Carb float adjustment - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-13-2004, 11:25 PM
Steve-0321's Avatar
i want to check the float level on my carb and i wanted to know when is it considered a wet adjustment and a dry adjustment...........and how do i tell when they are both in the correct positions to do so?.......its a motorcraft 2100D carb
Old 05-14-2004, 12:18 AM
2-manytoyzs's Avatar
Start those projects someday
Last journal entry: Divco - has been on the back burner
The specific float level will depend on the application. Set the float parallel with the top edge of the float bowl. It will be in the ballpark if you set it that way. There is no wet adjustment on a 2100.
