Carb Flooding - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-20-2006, 08:25 PM
Carb Flooding
Hi Guys and Gals, I just finished up on this motor which is a crate 350. I started the car and it ran fine for about 8 miles and it shut down. I went to start it up and the gas started pumping up thru the hole in front of the choke plate. This has a holley 600 cfm carb and when I bought it it was to be a new one!!!. The fuel pump is stock. Any help out there????. Thanks Don
Old 08-20-2006, 09:46 PM
97Z28's Avatar
NTI Grad.
are your floats set correctly? sounds like you have too much fuel pressure. is it a stock mechanical or electrical pump?
Old 08-21-2006, 06:31 AM
Crap Rod's Avatar
Legally Insane
Last journal entry: Project Road Kill
I had a simular problem .. what happend was a metering plate screw backed out and held the float down
Real easy to take a look inside ..
But as said above check the float level in the normal fashion first If no luck
pull the bowl off and take a peep.
Rick
Old 08-21-2006, 06:36 AM
T buckets rule
Do you have a good fuel filter just before the carb? If not you got some trash in the needle and seat.
Last journal entry: PICTURE TEST
carb
Probably some debris in the needle and seat. remove it from the bowl and clean it out with compressed air, or some carb cleaner..
Do you have a filter before the carb??? If not you need one..
Also, get that oil out of there right away... Fuel washed oil is extreamly hard on a new engine...
Keith
backfire thru carb airraptor Engine 11 06-12-2009 02:30 PM
Cleaning Carb Question oldcarguy36 Engine 17 03-04-2006 02:10 PM
Holley carb has me at wit's end cool rockin daddy Engine 23 06-02-2005 02:38 PM
edelbrock carb Vacuum problem? 75400truck Engine 16 10-03-2004 09:29 PM
rochester 4 jet carb, rich Walker Engine 2 07-13-2003 09:42 AM
