carb flooding cylinders - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2003, 12:50 PM
Post carb flooding cylinders
i have a 302 that has 4 barrel intake on it but when i install my holly 600 carb it floods the cylinders with gas and when i put my two barrel back on it runs fine but its not enough carb 4 my cam and doesnt have any power so i need my 4 barrel i u have any idea whats causing this please tell me thanks jj
Old 04-08-2003, 01:41 PM
72 chevy's Avatar
Post
Had the Holly been sitting on the shelf for a while? Is the mix adjusted properly? Possibly some crud causing the needle and seat to not seal...Bad float (full of fuel)or the float needs to be set a little lower. Those are what I would be looking at.
Old 04-08-2003, 01:49 PM
MI2600's Avatar
Member# 3287
Post
If the gas is just pouring out of the Holley, it's probably a float or needle and seat problem. Have you checked them?
