Carb gasket? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2004, 09:56 PM
Jag Daddy's Avatar
1969 Mustang Coupe Project Car
Last journal entry: New Project Mustang, From Jag Daddy to Stang Daddy
Carb gasket?
I was looking last night at the my Qjet and I noticed the gasket at the bottom of the carb looks like it's a layered paper. The layers look like they are coming apart. It's about 1/4 inch thick. Can I get rid of that gasket and replace it with a silicone bead? If I remove the 1/4 will it mess with the air fuel mix?
Regards
Mark
Old 04-10-2004, 10:09 PM
71 c-10's Avatar
just a kid and his truck
if you put silicone there then you have just glued your carb to your intake, just go buy a new base gasket there only a few bux
Old 04-10-2004, 10:18 PM
Does it have hard plastic doughnuts around all 4 bolt holes? If not, get one that does ('72 Nova w/350 4-bbl., for example). They keep you from warping the throttle plate when you tighten it down. I coat mine on both sides with Permatex Super 300 (or #3 Aviation) liquid & it comes off cleanly & can be reused.
Old 04-10-2004, 11:30 PM
71 c-10's Avatar
ya that type of gasket is what im talking about.. iv never heard of using sealer tho... o well if it works then i guess go for it.. im gona stick to not gluing but to each his own
