carb gasket deformed - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2011, 07:28 PM
GMR GMR is offline
Have an Edelbrock 1405 carb, Perf Prod spreadbore intake with a square bore adapter with upper and lower gaskets. When I removed the carb and adapter I saw this. The upper gasket looks fine. I don't think it came apart when I removed the adapter but I can't swear to it. There's no evidence on the adapter or anywhere else. Assuming it didn't come apart when I removed the adapter- have you seen anything like this before or any ideas what happened?
Old 02-08-2011, 08:04 PM
bigdog7373's Avatar
Of course it's fast
It looks like you need a new gasket, thats all. I cant tell much from the picture.
Old 02-08-2011, 08:12 PM
Last journal entry: Paint
Alway double check the gaskets. The slightest flaw can cause a vacuum leak. I had 2 brand new thick gaskets and I could see light between the gasket and manifold. I had the engine high enough where I could see it.
Old 02-09-2011, 01:14 AM
ericnova72's Avatar
More for Less Racer
There is nothing wrong in your picture other than the gasket should have been trimmed to fit the manifold opening without overhanging the plenum opening, or a different gasket with the correct size opening used. The pieces of gasket that are missing broke off because they were hanging in the breeze.
Old 02-09-2011, 01:17 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You used a a squarebore bottom gasket against the spreadbore intake. If you do this again, just trim the gasket so there's no overhang.
Old 02-09-2011, 07:28 AM
GMR GMR is offline
Thanks, now I'll do it correctly.
Gas leaking from carb, which gasket do I replace? madbrad Hotrodding Basics 3 01-06-2009 04:56 PM
Holley carb gasket vetteman Engine 1 10-28-2006 04:40 PM
Trimming Carb Base Gasket maverick19642001 Engine 4 09-03-2006 10:47 PM
leaking carb flange gasket Drugs Engine 5 08-10-2005 04:49 AM
Carb gasket? Jag Daddy Engine 3 04-10-2004 10:30 PM
