Carb gasket dual plane intake to 4 BBL - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-26-2008, 11:20 AM
I just realized I have the wrong carb gasket installed...or do I?
Edelbrock Performer 2116 dual plane intake
Edelbrock 600 CFM 4bbl carb
I have a standard square bore gasket on there now, but just realized that the intake/carb calls for a "heat insulator" gasket that has a strip of gasket material down the center. You can reference edelbrock part # 9266. That gasket mentions something about using it when underhood temps are a concern and you're boiling the fuel or something like that. I don't have that problem.
However, I have been chasing a very slight lean spot that I have been attributing to the 2ndary airvalve flapping open a little too early. Will/could a change to the correct gasket help?
Old 09-26-2008, 12:07 PM
Rustydawg's Avatar
Cruzin w/Elvis in Bigfoots UFO
Unless you have the fuel percolation problems that is mentioned in the Edelbrock documents, I would stay with what you've got.
I have experienced the same lean spot you speak of with Carter / Edelbrock carbs - the AVS has some adjustment on the air valve spring, the AFB style is a weighted air valve and doesn't adjust. I have heard of drilling out the counterweights to change the secondaries' behaviour but I wouldn't go there!
Otherwise your gasket should be sealing fine and won't cause any troubles.
Old 09-26-2008, 01:50 PM
Thanks, RD!
I'm ready to buy another carb that has some 2ndary adjustments. But, before I do I thought I'd go ahead and at least try to mess w/mine first. I have taken apart my Edelbrock and ground down the foot of the counter weights ever so slightly so the airvalves rest a few degrees closer to horizontal than stock. My thinking is that it will take a bit more velocity to open them because of the somewhat flatter resting position and there also seems to be some added mechanical leverage the counterweights have with this setup.
It shouldn't be too long before I find out how badly I screwed it up.
BTW-I have spent 2 years going through all various tuning adjustments/timing adjustments w/the carb and motor and feel I have exhausted all possible tuning avenues. This is my last resort...
Old 09-26-2008, 04:36 PM
Rustydawg's Avatar
I'd be interested to hear how your mods work out for you.
Now I don't feel like such a slacker for living with the same problem for so long!
I recently bought a dbl pumper to replace it - now that's something that you can tune every which way. The Edelbrock is very limited that way.
I was reading up on modding a Q-jet, even there you can open up an orifice that feeds fuel into the back half of the carb as the air valve opens, similar to a pump shot. I'm not aware of anything similar on the AFB clones.
Offenhauser Dual Port intake? 454C10 Engine 21 12-01-2007 10:28 PM
Intake Manifold Gasket Installation - Help leejoy Engine 7 10-29-2007 07:19 PM
Single or Dual Plane Intake. Skunk Engine 4 06-19-2005 08:10 PM
Stipud ? Maybe/Need help determining my Carb and intake ArchonRacing Hotrodding Basics 8 01-15-2005 06:03 PM
Dual Carb intake for a 351C Fordyce Engine 2 05-19-2002 01:47 PM
