Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - carb help
Thread: carb help
Old 01-29-2013, 08:11 AM
vinniekq2's Avatar
vinniekq2 vinniekq2 is online now
thats how the 650 dp works best. I found,when I used chokes on DPs,that I would partially close choke the choke,2 shots of the gas pedal,crank engine,engine fires,hold foot on gas,open choke most of the way,put in gear,drive away and open choke.
After a couple minutes car would idle,and smooth out with in 5 minutes.
I usually use single plane intakes and DP carbs,I live in Canada where humidity is very high on the coast.
