Carb help - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2011, 11:47 PM
Carb help
What carb do I use on a 1983 chevy k-10 it needs to be smoged, I'm
Putting a edelbrock cam in it as well.
Old 01-31-2011, 11:56 PM
SSedan64's Avatar
You're gonna have to use the stock type CCC Carb to be legal. There aren't any aftermarket Smog Carbs.
Old 02-01-2011, 05:21 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Better do your homework on the cam- too much duration/overlap will adversely effect emissions as well as drivability due to the computer's lack of flexibility. Basically, the vacuum the engine makes has to be a close approximation of stock when using the aftermarket cam
Many of Edelbrock's parts DO carry CARB certification. You might want to use their tech department to be sure you have a chance.
Old 02-01-2011, 08:45 AM
Carb help
Yes I have the 50 state smog legal cam with the Edelbrock intake
With the egr! What about the edelbrock cab #1400 will that work?
Old 02-01-2011, 08:48 AM
Carb help
I ment what about edelbrock carburetor #1400 will that work?
Old 02-01-2011, 09:04 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The 1400 is listed for '80-back GM vehicles. This means pre-CCC controlled emissions systems. The original carb you had may or may not have been a feedback-type carb. In CA, it most likely was- if it was an original CA emissions compliant vehicle.
You may need to contact a referee about this.
holley carb backfires threw carb talleyho Engine 63 01-04-2016 10:43 AM
Will adding a 1 inch carb spacer affect carb tune? eric32 Engine 29 02-09-2010 12:13 AM
Carb klx650sm2002 Off-Topic 2 01-04-2009 02:40 AM
Quadrajet Carb rebuild....parts interchange with another junk carb? Warrant Engine 2 07-31-2006 10:44 PM
Any problems spraying carb cleaner in my carb while its on the motor? batman09 Engine 11 11-29-2005 07:49 AM
