carb help - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-08-2004, 07:08 PM
New Member
carb help
holley 4160 vac sec carb, fuel is shooting up throu the tube on top of the carb on the secondary side
rebuild it and tryed to cracnk it up and this happend, wtf did i do?
btw, this is my 1sy attempt at rebuilding a carb
thank you
-chris
Old 05-08-2004, 07:13 PM
Sounds as though the needle & seat is stuck open or you adjusted the float incorrectly.
Old 05-09-2004, 12:07 PM
Technical Support Barry Grant
Remove the Needle & seat assembly, make sure it is moving freely, and reinstall.
Old 05-09-2004, 12:28 PM
johnsongrass1's Avatar
Race it, Don't rice it!
After making sure the needle and seat are moving freely double check that you have the right float in the correct side. One float arm will be slightly longer than another and this causes the float to come into contact with the metering block effectively preventing the carb float from ever closing until the float bowl fills up and over flows out the vent tube near the top. If I remember right, the brass float goes on the primary side.
Old 05-10-2004, 05:28 PM
New Member
fixed the problem, it was the floats....
now i have another question
when the car is idleing, fuel drops from the secondary side and not from the primary side .....before the rebuild it droped from the primary side whitch i would assume to be normal......
am i paranoid or did i mess somthing up?
btw, the two adjuster screws seem to do nothing
any ideas??
thank you
-chris
Old 05-11-2004, 06:04 AM
Fuel Dripping
Fuel should not be dripping out of the front or rear boosters at idle. There are a few things that can cause this to happen. First, your float level may be too high. Second there could be some dirt or debris in either the air bleeds, or metering blocks. Third, the butterfly's may be open too far.
Try lowering your float levels to see if this helps your situation. If it does not, clean out the main body, and metering block with some good carb cleaner, and compressed air. If the problem still persists re-adjust the butterflies.
Old 05-11-2004, 07:35 AM
Throttle blades are to far open.
You just said the idle mixture screws don't do anything.
