Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Carb Help Greatly Needed!
Old 12-05-2004, 07:47 AM
rodnok1 rodnok1 is offline
New Member
Sounds lasike the throttle shaft is sticking open, I had a TA that would do that couple times a year. Spray some WD40, or a silicone spray lube on both sides at the throttle shaft. Might take a few shots, then work the throttle with engine off then hit it again. It was a Holley Carb.
