carb help needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2004, 10:26 PM
New Member
carb help needed
ALright, I'll be honest, I'm new to the whole carb thing. I'm used to tuning using a palm/laptop for A/F and timing. So the 'simple' carb eludes me.
I know nothing more then it's a Holly. Here's a pic of it.
So, to start with, the car fell flat at anything more then half throttle, and reaked of unburned gas at idle. I checked the plug, and they were so fouled with carbon, I don't know how they fired. I swapped them out, and that seemed to help the idle a bit, but still had the same problem at half. So I adjusted the black knob on the side that had an arrow pointing Clock wise, to more lean. It seemed to do beter, and I got it so it feels pretty strong untill 50-60% and then stops acclerating altogether at %75 and up with some popping.
I assume it's lean, but I'm not sure what is the best way to go about this, and how much of a turn it takes to make a small change. So any help would be apprecated.
Old 10-21-2004, 10:54 PM
4 Jaw Chuck's Avatar
Start with a rebuild, that thing looks real tired.
BTW you adjusted the choke, its tuned like any other Holley carb.
— Han Solo
Old 10-22-2004, 08:58 AM
MI2600's Avatar
Member# 3287
I haven't seen a Holley front bowl like that. What is the List#?
The rich-lean adjustment is a small screw on the side of the front metering block.
Old 10-22-2004, 10:21 AM
New Member
Where would the list # be? I'll look for that adjustment screw. I'll do a search now and give you what numbers are where.
The list # is 8060-1, and below that is stamped 0717. I'm searching for info on it now.
Okay, it's a 650 CFM carb. Not really sure how to tune it or deal with the specific issues I have.
