Carb help PLEASE!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-03-2013, 11:28 PM
Carb help PLEASE!!!
I have a newly rebuilt Dodge 383(mostly stock components/bored 30 over) with about 500 miles on it. I have a new Edelbrock thunder series AVS 650 cfm carb w/ elec ck. I thought a new carb would help me to start fresh with no worries, but i have not gotten good results. I had an "older friend" that is familiar with working on mopars help me adjust the carb with his analyzer/tach meter and it seemed to run pretty well for awhile. Now it seems to run rich( you can smell it) when it warms up. The spark plugs on the right side of the engine are black and sooty, while the ones on the drivers side look normal. Also the exhaust is getting soot on the valance, and bumper. I am thinking about swapping to a Holley carb, because I can't find anyone in my area that can tune anything other than a Holley. Most of them don't think too highly of the edelbrock(carter-esque) carbs also. Anyone have any thoughts on this subject/ or what could be causing my problems? I am at the end of my rope!
Thanks
Mike
Old 06-04-2013, 05:48 AM
Irelands child's Avatar
An Edelbrock carb, Performer or AVS, will run out of the box and fairly well. BUT, they do need to be set up for your engine combination. That means working with the rods, jets, springs and fuel pump rod length. You also need to ensure that the fuel pump pressure at the carb inlet does not exceed 4-4.5 psig. Additionally, these carbs can be sensitive to dirt and a GOOD fuel filter installed. Fuel pressure and dirt will cause rich running. That carb came with a very good instruction book - you do need to read it (it can be confusing at first) and understand how to set that carb up as they do and will run very well. As far as "others" not caring for these carbs - if they didn't read that IB, then set that carb up accordingly, then they are the big losers. Holleys can and do have problems too but they seem a bit less sensitive to dirt and pressure.
Irelands child
Old 06-04-2013, 09:21 AM
Another thing to check is your timing. I had a issue with my holley carb and no amount of changes would get rid of it. Turned out to be a combination of my vacuum advance not being happy with my initial timing setting and after got that sorted out it now runs perfect.
I had to do a lot of tuning with my holley to get it running good and the edelbrock carbs are good carburetors as well. All carburetors have there good points and bad points but they still can be made to work good up to a certain point. What is your cam size as that can wreck havoc if its a bigger size cam. Also just like stated above fuel pressure is really picky with edelbrock carbs as they can't handle like what holleys do but not too far off.
Check the floats as it could be making to high of a float level and also does your carb get very hot? I have read that they got hot very easy and the fuel will boil over the side into the intake after it sits after running hot.
I used to run a edelbrock but I like that you can fine tune certain areas on the holley more then an edelbrock and I always got better throttle response with a holley. If your motor is pretty much stock and with a stock size cam then it should run excellent on your engine. Make sure to just tune one area at a time and make notes of what changes you made if you have too. It came in handy for me when I did changes and was able to go back to stock settings if what I did didn't make any difference. Good luck.
Eric
holley carb backfires threw carb talleyho Engine 63 01-04-2016 11:43 AM
350 carb question demon carb to much? Studedean Engine 5 04-22-2012 01:44 PM
Will adding a 1 inch carb spacer affect carb tune? eric32 Engine 29 02-09-2010 01:13 AM
Quadrajet Carb rebuild....parts interchange with another junk carb? Warrant Engine 2 07-31-2006 11:44 PM
Any problems spraying carb cleaner in my carb while its on the motor? batman09 Engine 11 11-29-2005 08:49 AM
