Carb. hesitation - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2004, 06:20 AM
Slant3's Avatar
84 Mutt
Last journal entry: Steering column
Carb. hesitation
Hi. I just put a 750 vac.sec.holley on my 406 and it fired right up.
Give it smooth slow revs, and it responds nice-- but when you tromp on it , it has a little "burp" so you come off and back on the gas quick and clears up. Any ideas????? Thanks.....
Old 08-21-2004, 12:02 PM
lluciano77's Avatar
Is the bog just out of idle? Are you flooring the pedal as fast as you can? Be more specific.
Is it an automatic trans. What vacuum does your engine run at in gear?
Is it a manual trans? What is the vacuum at idle?
Old 08-21-2004, 08:27 PM
Slant3's Avatar
84 Mutt
Yes it is out of idle---Auto trans----quick smash on the gas=baby bog--vac. while running is about between 15-20hg---idle is 17hg--touch the brake and vac drops to 12-10hg
Old 08-21-2004, 08:41 PM
lluciano77's Avatar
Whatever your vacuum is when the car is in gear, divide that in half and add .5. So if it is 16" you want an 8.5 powervalve.
So I am assuming it is immediately out of idle. Make sure there is instant pump shot. If there is, try increasing the pump shot.
Old 08-22-2004, 01:59 AM
Brian Morency's Avatar
Hauling A55 BURNING GASS!!!
Last journal entry: bros car
when the engine warms up does this problem go away? i had a problem with a edelbrock carb when it sits overnight and i try to start it i have to warm it up or it will die out, and when i try floring it right after i start it it bogs down then the power comes back until it is warmed up.something with the choke i believe.
