Carb install, spacer or no spacer? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2006, 03:16 PM
I'm putting this Holley on a Performer 460 manifold. My buddy gave me this spacer and gaskets. Holes line up but spacer has a center rib and gaskets are open except for the perimeter. Should I bolt up the spacer with a gasket on each side, should I just bolt up the carb with one gasket under it or should I get another gasket so the center is/would be sealed down the center rib in the manifold?
Name:	Torino carb spacer and gasket.jpg
ID:	10848   Click image for larger version
Name:	Torino intake open with gasket and spacer.jpg
ID:	10849   Click image for larger version
Name:	Torino open intake and carb.jpg
Old 03-17-2006, 03:26 PM
GoneNova/406's Avatar
i always use 4 hole spacers on dual plane intakes.
Old 03-17-2006, 04:05 PM
aka Duke of URL
The one shown on the left is the correct one for the shown intake plenum. It is also a heat insulator whereas the open gasket is not. Just make sure there is no interference between the insulator and the carb venturi plates.
Old 03-17-2006, 06:23 PM
So, I use the spacer without the open gaskets? i.e. the spacer is also a gasket. It's a soft composit material so I wondered.
Thanks.
Carb spacer question Gametech Engine 5 05-21-2005 10:04 PM
Carb spacer 72elcamino Engine 6 11-12-2004 09:30 PM
am i choosing the correct carb spacer? Super Chevy Engine 13 02-18-2004 03:02 PM
Carb Spacer Question dollybud Engine 1 01-14-2003 06:23 PM
Carb Spacer Question dollybud Engine 1 01-14-2003 03:27 PM
