Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Carb insulator gasket
Old 11-17-2011, 10:44 PM
rustman rustman is offline
Streetbruiser. When your talking about the bypass air are you talking about the channel on the carb base by the primaries or the channel on the intake by the primaries? I went back to the Quadrajet wedsite and it says to put the stainless heat shield gasket directly under the carb and on top of the 1/4" spacer. It seems to me that the heat would be coming from the manifold and not the carb.
