Carb and intake...?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2012, 11:07 AM
Buick b4's Avatar
Hi,i want to upgrade my stock intake(chevy 350) with Edelbrock and on other side i decide to change my 4bbl Rochester with Edelbrock 1406,which intake should i use for best mileage and performance??
Is it a good idea to have these parts(Edelbock) instead of stock one(Rochester)??
Old 06-10-2012, 11:14 AM
Thumpin455's Avatar
Ask me about Ethanol
Last journal entry: 65 GTO
How expensive is your gas in Iran? A well built Qjet will outperform an Edelbrock carb easily, in power, drivability, and mileage. The E carb will work, run well, but it wont do anything great. The Qjet is more complex than the E carb, so you have to know something about them whereas the E carb is a bolt on and go, maybe change the metering rods. Your choice.
The Following User Says Thank You to Thumpin455 For This Useful Post:
Buick b4 (06-15-2014)
Old 06-10-2012, 11:36 PM
Buick b4's Avatar
Carb
Each gallon is 1.60 dollars how ever it was really cheap before revolution...!
In compare with US it is still cheaper but we don't have a good income here(1000 dollars in a month...)
Thank you for helping,is it a good idea to have a new inake for my Rochester? Rochester is a good carb but mine use much fuel!!
Old 06-11-2012, 07:38 AM
Edelbrock "performer" is a good intake for a mild street engine. It will improve volumetric efficiency at lower engine speeds, over the factory intake. For higher "revs", Performer RPM is called for.
If your Q-Jet is providing poor mileage, something is "wrong". As Thumpin455 said, Q-Jet is an excellent carb, FAR superior to the E-carb (IMO). A certain amount of expertise is necessary to "get it right". Cliff Ruggles has published a book through SA Designs detailing the process for a good result. He (Cliff, "Cliff's High Performance") aklso provides a very good rebuild "kit" for any model of QJet.
Jim
The Following User Says Thank You to Mr. P-Body For This Useful Post:
Old 06-12-2012, 05:48 AM
Buick b4's Avatar
Thank you so much !!!
3 carb intake bigtank05 Engine 4 09-23-2008 02:55 PM
My intake and carb? 71haulnazz Engine 3 09-16-2008 10:27 AM
carb and intake kevin35 Engine 2 01-04-2006 05:14 AM
which intake and carb 82c10 Engine 7 07-05-2005 10:19 AM
LT-1 Carb Intake MI2600 Engine 3 05-11-2005 05:59 AM
