Hotrodders Bulletin Board
#1
carb and intake question
i have a weiand stealth intake pt#8016 and a edelbrock carb pt#1406.. i have been having idle problems and im wondering if i have the wrong intake for the carb. im thinking i might need a edelbrock intake pt#2101. could someone confirm this..here are pics of the 2 intakes....
#2
re: carb and intake question
1406 should work fine. What idle problem are you having?
#3
carb wont idle in gear unless i up the idle screw to about 650 to 700 rpms which is about 1000 rpms in park.. if i idle the carb down to about 650 to 700 rpms in park it dont sound right ..the motor jumps around and you can just tell its not running smooth at all...since the last time we talked i've changed intake gaskets i've changed jets rods ,carb spacers ..lol..you name it..i can drive the car anywhere with no troubles as long as i idle it up so it will not die in gear.i;ve even went out and bought a new holley and it done the same thing..i thought maybe it was just the wrong intake and carb combo..i had a 88 chevy pickup with the same intake and carb and it ran fine(305sbc)
#4
Sounds like the transmission is over loading the engine when in gear. Wrong TV cable adjustment, or an internal transmission pressure problem.
#5
Dorp it into gear and pull on the kick down cable and see if it idles ok.
#7
nope still idles funny.. the two intakes i posted pics of look very different could that be my problem.. does one intake do better than the other with the carb i have..i didnt buy this intake thats on the car so i was thinking that the guy i bought the car from just installed the wrong intake and carb combo..
#8
Try disconnecting the TV cable and how does it idle in gear? What jets and metering rods do you have in it?
#9
how big your cam , need a stall converter if over 270 duration
#10
right now i got it set like it came new...098 primary...095 secondary.. .075" x .047" rods...orange (5") springs.. i've had the trans kickdown cable completly off the carb and still idles bad..i put it back and it works .i can floor it and the trans does kick down to lower gear. i've went with .095 jets primarys and .098 jets secondarys and it was worse so i put it back the way i had it..i have used every rod i have in the cal.kit and i've used every spring and no better..i mean the carb dont hesitate or bog down ..it takes gas good and never stands on its face ...i've even changed the needles and seats with new ones ...i've used a vac. gauge to set the mix screws and i get a steady 15 and i can't get more right now the mix screws are about 1.5 turns out.. i still get 16hg at intake vaccum but i was told that was normal for the cam i have .. (hydraulic flat tappet 68-81 L-46 and L-82 Corvette. The duration at lash point in degrees (intake/exhaust) is 312/312; duration at .050" tappet lift (intake/exhaust) is 222/222 and maximum lift with 1.5:1 rocker ratio (intake/exhaust) is 450/460. Valve lash is zero/zero and lobe centerline is 114 degrees.) this is the cam i have
#11
this is the engine i have.....http://www.crateenginedepot.com/sto...29-P824C53.aspx
#12
What color are your plugs? |
Back to top |
Similar Threads for: "carb and intake question"
| 350 Intake question | oregon chevelle | Engine | 4 | 02-17-2006 04:27 PM |
| Intake Manifold and Carb | Ozz1967 | Engine | 9 | 12-29-2005 11:34 AM |
| Fabricating intake manifold. | gemini86 | Engine | 20 | 05-12-2005 11:08 PM |
| Intake & Carb question | Houman SS '70 | Engine | 31 | 03-24-2005 04:05 PM |
| Holley Carb. Question | JamesRS | Engine | 3 | 02-20-2003 01:27 PM |
